Help , Muffler touching tire
Old 07-24-2014, 06:49 PM
Mohammed_z
Mohammed_z's Avatar
Default Help , Muffler touching tire
I removed the exhaust to install the hurst shifter. Installed fine and shifter is cool.
But after returning back the catback , the left muffler touches the tire !! I don't know why and the muffler shop says there has to be some cutting in order to fix this problem !! I think he is not right about the cutting because nothing was done, just removed and install back !
flowmaster mufflers with custom x-pipe
LEFT TIRE
Right tire
Can you guys measure the distance on your car , between the muffler and tire.
Old 07-24-2014, 06:59 PM
Bandit's C4
Bandit's C4's Avatar
Central PA Events Coordinator
St. Jude Donor '12-'13
The question is... did you measure the distance between the old (before install) and new set (after) mufflers?
Old 07-24-2014, 07:06 PM
Mohammed_z
Mohammed_z's Avatar
I didn't change the mufflers, just painted them black.
Didn't measure before removing the catback, but it wasn't so close like that.
Old 07-24-2014, 07:34 PM
BOOT77
BOOT77's Avatar
How do the tips look? You may have to loosen everything up and shift the exhaust back over to were it was.
Old 07-24-2014, 07:46 PM
PLRX
PLRX's Avatar
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20
Loose those clamps, and use your imagination.
To close to the left, push the whole system to the right.
Old 07-24-2014, 08:14 PM
corvetteronw
Support Corvetteforum!
corvetteronw's Avatar
Cruise-In VII Veteran
Cruise-In VIII
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
I have installed the Corvette Central Magnaflows and rear Y with crossover pipe on 3 different L98s. I had the same problem with my last install. I tried everything and finally in frustration took it to the local hot rod shop. They cut a small piece off the front of the muffler inlet pipe and put it back together - worked fine after that!
Old 07-24-2014, 10:42 PM
Tommycourt
Tommycourt's Avatar
Please correct me if I am wrong however I thought that Magna Flows and Flowmasters were supposed to fit without any alterations. I wanted to just mount mufflers on and not worry about going from the cats back but now I am beginning to wonder if I should.
Tommy
Old 07-24-2014, 11:12 PM
hooked073
hooked073's Avatar
and no one removed any of the tires while doing this??
Old 07-25-2014, 09:17 AM
c4cruiser
c4cruiser's Avatar
It does look like one of the pipes at the front end didn't get inserted far enough. The difference in distance between the before and after pics looks like it can easily be corrected by loosening the clamps in front and moving the system to the right. Exert some forward pressure on the system while moving it.
Once you have the distances equal on both sides, tighten down the clamps and install the hanger bracket at the differential.
Old 07-25-2014, 10:23 AM
Mohammed_z
Mohammed_z's Avatar
No ,
I will try this when taking it to exhaust shop.
Old 07-25-2014, 11:10 PM
Mohammed_z
Mohammed_z's Avatar
UPDATE :
Went to the shop, we loosened the clamps little. Tried to move the system and the tips look fine from behind.The muffler moved just a little from the tire. The right still far while the left is close. It's about an inch and a half.
Its better than before.
Time to search for new catback system, i never liked the flowmasters
Old 07-26-2014, 04:42 PM
Red89'-L98
Red89'-L98's Avatar
FL Events Coordinator
St. Jude Donor'13
I have a really good eye for this kind of stuff and when I loo at the exhaust system laying on the ground to me it looks bent and not symmetrical like it should be. It could be the picture or I could be wrong, but to me it looks bent out of shape.
Old 07-26-2014, 07:35 PM
Mohammed_z
Mohammed_z's Avatar
Another reason i found that the flowmaster system on corvette central catalog doesn't come for 92+ , so the one installed is for 91 and below.
Old 07-26-2014, 09:48 PM
eschoendorff
eschoendorff's Avatar
St. Jude Donor '08
Eliminate mufflers. Problem, solved. Prolly will sound cool with the custom X pipe.
To Help , Muffler touching tire
Quick Reply: Help , Muffler touching tire
