Shifter console bezel
Old Jul 25, 2014 | 08:32 PM
zioncat's Avatar
zioncat
Cruising
Default Shifter console bezel
Any "how to's" of removing shifter console bezel. I think I read that you have to first remove both the instrument bezel and the radio bezel. Is this true?
Old Jul 25, 2014 | 09:24 PM
RollaMo-LT4's Avatar
RollaMo-LT4
St. Jude 15 Year Donor
2021 C4 of the Year - Unmodified Finalist
St. Jude Donor '10 thru '25
It would probably help a great deal if you would list the year of your car, and if it is an automatic or manual transmission.
Not all C4's are the same.
Old Jul 25, 2014 | 10:34 PM
zioncat's Avatar
zioncat
Cruising
Of course RollaMo. My bad. '96 LT1,automatic
Cliff Harris's Avatar
Cliff Harris
If you have a '84 through '89 C4 that is true. The bezels interlock, so you have to take off the dash bezel to get the center bezel off.
That's not 100% true. I think you could take out all the dash bezel screws and then move it outward enough to unhook it from the center bezel. I have not tried this, but I believe it would work.
Old Jul 26, 2014 | 07:33 AM
moco65's Avatar
moco65
No need to remove the radio bezel. I have a 94 6 speed. If I remember correctly, there are three screws to remove - one under the ash tray/cup holder and two on either side of the rear of the shifter bezel, under the center armrest. Seem to recall there are tabs at the front of the console that slide under the radio bezel, holding everything in place.
Old Jul 26, 2014 | 09:17 AM
C4in mesa's Avatar
C4in mesa
Not that it applies to the OP but for 84-89 the instrument bezel does have to be unscrewed enough to pull it away from the radio bezel which goes behind the instrument bezel. The radio bezel covers two screws on the shifter bezel and has to be pulled back in order to come off. Personally I take my time since these parts aren't cheap to replace. I paid $120 from Corvette Central for my automatic shifter bezel.
Old Jul 26, 2014 | 11:01 AM
Dt86's Avatar
Dt86
Originally Posted by Cliff Harris
If you have a '84 through '89 C4 that is true. The bezels interlock, so you have to take off the dash bezel to get the center bezel off. That's not 100% true. I think you could take out all the dash bezel screws and then move it outward enough to unhook it from the center bezel. I have not tried this, but I believe it would work.
Yes. I have done this.
Old Jul 26, 2014 | 11:10 AM
C4in mesa's Avatar
C4in mesa
I was only putting caution to the wind as this plastic is very brittle and bending it around and testing its limits is not something I would do when to avoid anything from breaking is to simply take the time to remove a few more screws.
To Shifter console bezel
