92 c4 idle problems
Old Jul 25, 2014 | 09:29 PM
lectroglide's Avatar
lectroglide
Default 92 c4 idle problems
ok guyz heres my story. month ago picked up a 92 C4 with 124K miles. at the time it looked fantastic and ran good. so I took it ion for an inspection at a vette shop and they noted it needed front shocks, front pads and a cooling temp sensor. The person I got it from had replaced the opti-spark and on-board computer so that was outta the way.
I just did the shocks and front pads also the cooling temp sensor. I mostly replaced the CTS cuzz the car was idleing rough in drive when stopped at a light, but drove down the road real good! Right after the CTS was replaced I had thought the idle problem was gone but it came back. The guy that replaced it showed me the scan readout before and after the change which showed great improvement! but still the idle problem was still their and still is now.
I did the injector "screw driver test" and all 8 seem to be pulsing ata steady rate, so don't think that could cause the bad idle, but not sure, I bought a can of BG44 in hopes it might make a difference, isn't here yet so will see.
Anyway am needing suggestions what could be causing the problem.
Once again the problem is the car wants to pulsate when in gear and stopped at a light but runs fine goin down the road. BTW its an automatic
Old Jul 27, 2014 | 03:10 PM
Sassman's Avatar
Sassman
Mine presented the same symptoms. Turned out it was the Opti-Spark.
Old Jul 27, 2014 | 03:51 PM
lectroglide
how can that be, it and the water pump were just replaced 2/14
Old Jul 27, 2014 | 04:04 PM
Sassman's Avatar
Sassman
It may very well be something else. I merely stated that my '94 presented the same symptoms. Replacing the opti-spark remedied the problem. Do a search of this forum. You'll find that a new opti-spark can go wrong just like one with 50,000 miles on it. They are the twitchiest component to our LT-1 engines.
Old Jul 27, 2014 | 04:13 PM
lectroglide
if it makes any difference this on was replaced 2/14 the old owner took it in cuzz the car wouldn't start, but then did but died. My problem is the car runs rough when ata stop light, then runs fine when rolling
Old Jul 27, 2014 | 05:03 PM
1993C4LT1's Avatar
1993C4LT1
Rough idle, my guesses are opti or plug wires. On the 40th Ruby I bought, the opti was recently replaced. It died on me 3 weeks ago. Looked good visually, but the shaft made a grinding noise when I'd turn it by hand. Was also hard to turn it. Good luck
Old Jul 27, 2014 | 09:55 PM
lectroglide
thanx for the reply, just had it out today but now the problem is intermittent so somethings changed. another question is why the rough idle when in gear and stopped but not going down the hiway?
Old Jul 27, 2014 | 10:08 PM
1993C4LT1's Avatar
1993C4LT1
No problem. I'm not sure why. But I've heard that the batch fire injection
on these lt1 engines, have a rough idle and it's their nature.
Old Jul 27, 2014 | 10:19 PM
lectroglide
batch fire?? its a 92
JVH's Avatar
JVH
Has any internal engine work been done ? I'm just askin cause mine has a pulsating idle but it's cause of a different camshaft. If the car is new to you the previous owners might know
Old Jul 27, 2014 | 10:28 PM
1993C4LT1's Avatar
1993C4LT1
Yes, the '92-'93 LT1 has the batch fire injection.
Old Jul 27, 2014 | 10:30 PM
lectroglide
I have a list of things that were done, can post now if ya want
Old Jul 29, 2014 | 02:41 AM
ANTI VENOM's Avatar
ANTI VENOM
Yes, post them up.
JFYI, batch fire just means that all the injectors fire at the same time. Not sure if you knew that or not. It works just fine.
Does it idle fine in Park? What is the IAC count at idle in gear? Is it in closed loop or open loop when idling in gear? What was the guy using to look at the CTS?
Old Jul 29, 2014 | 06:01 PM
lectroglide
Originally Posted by ANTI VENOM
Yes, post them up.
thnx for the reply and to be honest I cant really answer the question so might have to have a visit to the shop
Old Jul 29, 2014 | 07:15 PM
92ragtop's Avatar
92ragtop
2019 C4 of Year Finalist (appearance mods)
2015 C4 of Year Finalist
Another thing to try is removing the throttle body and giving it a good cleaning, including the orifices to the IAC. It also might be the IAC itself.
Old Jul 30, 2014 | 01:03 AM
lectroglide
IAC ?? yes I need to get in their and check things out
To 92 c4 idle problems
