87 corvette
Old Jul 26, 2014 | 04:04 PM
rayax's Avatar
rayax
8th Gear
Default 87 corvette
Hello new to the forum. Been lurking for a bit and found lots of good info. But now I need someone's expertise. There is a guy here locally in ohio who is selling an 87 as an edelbrock edition car. I have never heard of this but I am not as well versed on these. It is basically all edelbrock shocks etc... can anyone inform me on this car??
Old Jul 26, 2014 | 06:09 PM
Bobby Brewsky's Avatar
Bobby Brewsky
I've owned a 1987, never heard of an "Edelbrock Edition". What does the "etc" include?
I found this:
http://www.carid.com/1987-chevy-corv...-17638142.html
Who did the work? How long ago? How many miles on the car? What's the asking price?
Old Jul 26, 2014 | 06:50 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Sounds like a "custom edition" to me.
Old Jul 27, 2014 | 08:32 PM
rayax's Avatar
rayax
8th Gear
Apparently all the control arms suspension parts basically top to bottom is stamped/labeled edelbrock. Never heard of or seen anything like it.
Old Jul 27, 2014 | 08:37 PM
rayax's Avatar
rayax
8th Gear
I found this:
he is asking 5000.00 all black convertible. 125,000 miles sounds and drives like new. All guages work, has some scratches etc...
Old Jul 27, 2014 | 10:28 PM
jv9999's Avatar
jv9999
Not a bad price for a rag top, Edelbrock or not.
Old Jul 28, 2014 | 12:09 AM
hooked073's Avatar
hooked073
I have hears of eledbrock shocks, intake and runners for a c4 I have never seen or heard of controll arms sway bars springs for a c4 or a Eledbrock custom special edition ect
Old Jul 28, 2014 | 08:21 AM
ghoastrider1's Avatar
ghoastrider1
lowest price I have seen for a vert in a while( in decent shape). I have an Eldebrock intake and runners..cost you a thousand bucks to do the same.
Old Jul 31, 2014 | 06:30 PM
rayax's Avatar
rayax
8th Gear
well, I went and looked it over and it basically appears shocks and and maybe runners etc.. are edelbrock. the guy was told it was and edelbrock edition with all that stuff and it is not marked on any suspension parts except shocks lol... still a nice enough car may buy it here are pics.
Old Jul 31, 2014 | 06:31 PM
rayax's Avatar
rayax
8th Gear
not sure who put the ss badges on it?? it has the original bose radio for it as well
Old Jul 31, 2014 | 08:54 PM
c4cruiser's Avatar
c4cruiser
After looking at the pics, I would suggest you keep looking. With the radio out, there is no way to verify that it works or that the speakers/amps are OK. Looks like some wear and tear on the seat covers and that can cost at least $1K or maybe more for new covers and foam.
The engine pic shows a couple things; the MAF sensor is installed upside down Not sure why somebody would do that but if it runs... But it could easily be contacting the hood and that can cause it to eventually break. The brake master cylinder reservoir looks pretty nasty. Do you know how good the brake are??
The passengers side tire looks like it's nearly bald on the inside. Bad alignment, bad suspension, and probably an old tire.
Looking just past the HEI distributor cap, there a yellow wire nut at the end of a wire . that's for household electrical wiring, not for automotive electrical wiring. Looks like the owner did a coolant bypass on the throttle body and used about a foot more of hose that needed.
And there's no wiper arm on the driver's side
Carefully check out the condition of the weatherstripping. It can be very expensive to replace 'vert weatherstripping
Maybe the price is decent for a convertible, but I think this one may cost that much more to get it into good shape. For $10K there are a lot of later C4 'verts in very good condition.
Old Jul 31, 2014 | 09:13 PM
corvetteronw's Avatar
corvetteronw
Cruise-In VII Veteran
Cruise-In VIII
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
Hard to tell but are there a lot of scratches in the paint?
I would keep looking. The more of them you look at the more you will learn. You might come back to this one later as it will probably still be there.
Old Jul 31, 2014 | 09:57 PM
rayax's Avatar
rayax
8th Gear
I drove the car the brakes are great. Runs really good and strong. The seats seem to be mostly be dirty. It does have a small spot on the passenger seat about dime size that shows were. The seller has came down to 2800.00 probably gonna buy it it is over all in good shape runs fantastic.. it out of alignment so that should correct the tire issue
Old Jul 31, 2014 | 10:11 PM
jay1055's Avatar
jay1055
Default I
For $2800 you should be ok
Old Aug 1, 2014 | 06:45 AM
rayax's Avatar
rayax
8th Gear
There are a pot of scratches, but my buddy has a paint shop that I use so that part really isn't a big deal. Basically a 12 pack and the weekend we will have to done.
Also I really appreciate all the help, you guys have been great.
Old Aug 1, 2014 | 09:35 AM
FOURSPEEDVETTE's Avatar
FOURSPEEDVETTE
All the Edlebrock edition Corvettes came with those big SS emblems on the side. Just a note. There was never a "Edelbrock Edition" Corvette produced from GM.
Old Aug 1, 2014 | 10:27 AM
MavsAK's Avatar
MavsAK
Those are factory intake runners.
The lower intake manifold if you look close you'll be able to see Edelbrock written on it. If it doesn't have that, then it's probably a completely stock intake.
To 87 corvette
Old Aug 1, 2014 | 10:31 AM
N227GB's Avatar
N227GB
St. Jude Donor '14 thru '20, '23 thru '26
If the owner throws in the can of Busch that's sitting on the ragtop in your second picture, you'll only need five more cans for your buddy.
That's a red flag to me. I'd wonder how many other things will need to be corrected.
Old Aug 1, 2014 | 10:40 AM
MavsAK's Avatar
MavsAK
Wait...where's the second master cylinder reservoir?
Old Aug 1, 2014 | 10:52 AM
FOURSPEEDVETTE
I think they changed them to one reservoir in 1986. Non the less, the brake fluid looks terrible. Very dirty.
