Battery drainage
Old Jul 28, 2014 | 11:10 AM
uduhman11's Avatar
uduhman11
5th Gear
Default Battery drainage
Newer battery on my C4 drains to 0 quickly...have checked various reasons...none of which have worked...HELP!
Old Jul 28, 2014 | 11:55 AM
wydopnthrtl's Avatar
wydopnthrtl
Can't help much other than to say: Is it actually draining or is the battery degraded to the point where it doesn't take much normal drainage to kill it.
I've "heard" C4s eat batteries. Mine was dead when I bought it. New battery and the car can sit for 2weeks. Starts just fine and I see 14.2V on the digital guage.
Old Jul 28, 2014 | 12:55 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
If the battery tests as good, put a full charge on it.
Connect a DMM between neg lead and ground and mesaure mA of current draw.
If greater than 50mA begin pulling fuses, one by one to isolate the problem circuit.
Old Jul 28, 2014 | 02:24 PM
RollaMo-LT4's Avatar
RollaMo-LT4
St. Jude 15 Year Donor
2021 C4 of the Year - Unmodified Finalist
St. Jude Donor '10 thru '25
A C4 isn't going to "eat" a battery any more or less than any other modern car.
If you have an substantial electrical draw while the car is not running, the battery is going to go dead in short order.
Not any different than any other car.
The problem is these are now "old cars" and there are numerous electrical issues that current and/or previous owners have failed to take care of.
Fix the problems and the car can sit for weeks and/or months at a time without any issues.
Old Jul 28, 2014 | 06:34 PM
GCM's Avatar
GCM
5th Gear
My 84 Vette, starting with a fully charged battery and new alternator, will only show a maximum of 13.4 volts on the dash voltmeter which steadily drops throughout the day as I am driving it until it gets down around 12.4 volts whereupon it dies and will not restart. I have been through 2 new batteries and 2 new alternators with no change so I know that the problem does not exist with this part of the charging circuit. Someone suggested that this could be a problem with the charging wire off of my alternator and possibly a fusible link or the excitation wire to the alternator. Can anyone tell me how to find the actual problem?
Thanx
GCM
Old Jul 28, 2014 | 07:13 PM
WVZR-1's Avatar
WVZR-1
Thanx
GCM
Since you've been through 2 batteries and 2 alternators we'll have to assume you're tools for electrical diagnostics are very limited. I'd suggest having the charging system checked with everything in the car and the entire system evaluated. A local smaller electrical shop would be your best and likely least expensive options. Any of the mentioned items could be the culprit but it get's pretty detailed to explain the diagnostics involved for all of them. Undoubtedly someone will say take a volt meter and do this or that BUT the real diagnostics need to be accomplished by someone that understands. With a "carbon pile load test" meter the complete electrical charging and cranking systems can be evaluated "on the car"!
If you want to do some interesting reads using Google search just check for carbon pile load test evaluation of electrical system. You should find several good reads.
Here's a start that's orientated for heavier equipment but it's quite complete for each component:
http://delcoremy.com/Documents/diagnostic-manual.aspx
To Battery drainage
