87 differential
Old Jul 29, 2014 | 12:33 PM
jwebster2's Avatar
jwebster2
4th Gear
Default 87 differential
whats the easiest way to drain the differential. I don't want to drop the whole rear end
Old Jul 29, 2014 | 07:04 PM
c4cruiser's Avatar
c4cruiser
Get a cheap fluid pump from Harbor Freight. That is the easiest way to get the fluid out.
You can also install a drain plug. Some of the accessory catalogs have a drain plug that will self-thread after drilling a hole in the bottom of the diff case. You have to be careful as the location of the hole has to be fairly precise.
But for the most part, draining and refilling the diff gear oil is something that doesn't need to be done at regular intervals; maybe something like every 75-100K miles. Make sure to use a good GL-5 80W-90 gear oil and a bottle of GM positraction additive.
Old Jul 29, 2014 | 09:37 PM
H P Bushrod's Avatar
H P Bushrod
Moderator Emeritus
St. Jude 15 Year Donor
CI 5 thru 12 Veteran
St. Jude Donor '09 thru '23
Had my fluid changed in my '93 not too long after I bought the car, when it had 73,000 miles on it. That was almost seven years ago. I just went over 100,000 earlier this month. No problems.
To 87 differential
