vent help
Old Aug 2, 2014 | 02:07 AM
85vegasvette's Avatar
85vegasvette
Default vent help
ac blows out from defroster, vents and heater, no matter what setting its on, max, normal heat etc, my cruise control works so is it safe to rule out vacum leak, if so would it be the actual dash unit
Old Aug 2, 2014 | 02:33 AM
Cliff Harris's Avatar
Cliff Harris
Based on your Forum name, I assume you have an '85. If so then you have the C60 manual HVAC system.
The main question is: Is vacuum getting to the HVAC control head? All the air doors are controlled by vacuum from the control head, so if vacuum is not getting there then you won't have any control over where the air comes out.
