engine warm string problem
Old Aug 13, 2014 | 04:49 PM
oldtimer's Avatar
oldtimer
Default engine warm string problem
MY '92 Vette LT1 w/108,000 miles is difficult to start when warmed up. Cold start no problem. I replaced the plugs and wires (WHEW) hoping this would solve the problem. It did not. My next attempt to solve the problem will be to place a injector cleaner with the fuel. Got a fairly new K@N air cleaner in place. This problem wasn't a progressive problem it came one day a couple weeks ago. Any thoughts will be appreciated. Thanks Guys.... and Gals
Old Aug 13, 2014 | 05:50 PM
nicpete's Avatar
nicpete
i had a problem with my 93 would not start when hot after it sat for 30 minutes it would start,turned out to be the starter
pete
Old Aug 14, 2014 | 10:41 AM
gtp'n's Avatar
gtp'n
Another member on the forum had this same issue on a 94 last week I think. It was the throttle position sensor. Replaced it and they have not had a problem since.
He bought one for an LT1 Camaro since the auto parts store did not have one for the LT! Corvette in stock lol The Camaro one was half the price I think.
Old Aug 14, 2014 | 12:29 PM
LannyL81's Avatar
LannyL81
oldtimer: is it only hard to start when warm or does the engine also stumble when warm?
I assume the starter is working and turning the engine, but it is just not firing...right??
Suggest checking fuel pressure when engine is warm.
Also check spark color with engine warm.
Old Aug 14, 2014 | 12:32 PM
oldtimer's Avatar
oldtimer
Thanks for the info going to run a injector cleaner thru first and if that fails will try your suggestion.. Thanks again this site has come to the rescue for me several times in the past 12 years.
Old Aug 14, 2014 | 07:07 PM
oldtimer's Avatar
oldtimer
Originally Posted by lannyl81
oldtimer: Is it only hard to start when warm or does the engine also stumble when warm?
only hard to start after warm.. It runs perfectly after start
Old Aug 15, 2014 | 06:48 PM
oldtimer's Avatar
oldtimer
Bought a TPS ...it solved my starting problem... Thanks
To engine warm string problem
