Radiator time
Old Aug 16, 2014 | 08:15 PM
primalurges's Avatar
primalurges
Default Radiator time
Time to replace radiator on LT4. I'm in the south east and temps are usually in the 90s during the summer. I drive the car just for cruising no track duty and not a DD. Will a dual core aluminum radiator really make a notable cooling difference? I can afford a higher price aluminum radiator but would only do so if it really made a difference. Thought anyone?
Old Aug 16, 2014 | 09:02 PM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
Search "radiators"
Not to mention the twenty other threads on the subject in the past two weeks
Old Aug 16, 2014 | 09:20 PM
COCOLOCO's Avatar
COCOLOCO
DEWITTS
Old Aug 16, 2014 | 11:32 PM
enventr's Avatar
enventr
You may want to change your fan setting and put in a 160 stat if outdoor temps are that hot. I put in a Dewitt's and love it but my system is stock so maybe a couple degrees cooler not much. When I move to Florida I may reset the fan on and off times and change to a 160 stat coupled with a Dewitt's it should run a lot cooler
Old Aug 17, 2014 | 07:17 AM
PcolaPaul's Avatar
PcolaPaul
Have you had any engine related failures due to the stock radiator size?
Why re-engineer the stock cooling system.
The LT engines are designed to run HOT. The cooling fans come on at 228°. If the engineers at GM wanted the car to run 180°, they would of programmed the fan to come on at a lower temp, had a lower temp t-stat and a bigger radiator.
Stock, leave it alone. If you add a bigger radiator, keep the factory recommended T-stat and fan temps.
Higher temps keep condensation out of the oil and make the engine efficient as designed.
Old school guys like a cool running small block and consider anything over 180 hot. Its a hard habit to change for us old school Guys. Leave it alone and let it run as designed.
Old Aug 17, 2014 | 09:29 AM
Geardo's Avatar
Geardo
They ran the engine hot for emission reasons, not for the life of the engine.
Old Aug 17, 2014 | 09:35 AM
3JsVette's Avatar
3JsVette
Originally Posted by COCOLOCO
DEWITTS
If you want to avoid any drama while you can spend less you will get what you paid for.
Old Aug 17, 2014 | 11:04 AM
scotth48's Avatar
scotth48
DeWitt's, most reliable way to go for the long haul!
Old Aug 17, 2014 | 01:12 PM
GKK's Avatar
GKK
Stock radiator is just, Fine!...
To Radiator time
