Suggestions for Head Light Replacement
Old Aug 23, 2014 | 11:54 PM
Hary Gahtoe's Avatar
Hary Gahtoe
Here's just some of the links for DIY building top notch projector HID's
http://www.hidplanet.com/forums/show...ector-retrofit
Old Aug 24, 2014 | 08:11 AM
vetteman42's Avatar
vetteman42
Active Streak: 90 Days
Originally Posted by vetteman42
Give them a call too very helpful and friendly!
Got H4 Hella replacements and have choice of bulbs. Had them about ten years without any issues......no change in fuse needed.
Good Luck!
SAVE THE WAVE
Don't know why my link was singled out.....but search for Susquehanna Rally Lights.
SAVE THE WAVE
Old Aug 24, 2014 | 11:21 AM
Hary Gahtoe
Hella were top notch before projectors, then came even cleaner and brighter HID's.
I had a C5 which I bought the GM Euro glass lens by Hella. It allows you to order aftermarket replacement bulbs and I bought a set of PIAA white light bulbs. The whole setup worked better than OEM but the pattern and the light quality were sadly lacking compared to my sons VW GTI with factory (read average )HID projectors
HID's can be retrofitted to OEM wiring harness without blowing fuses or damaging wiring.
The light output of HID projectors retrofitted to the OEM housing is as good as it gets for now
