85 horn problem
Old Aug 19, 2014 | 12:57 PM
Mike1985's Avatar
Mike1985
Default 85 horn problem
Just purchased my first corvette a little while ago. When I got it the horn worked now the horn isn't working but I seem to hear a click behind the dash. Could my horn just be shot or is a fuse blown? And if anyone knows, does the 85 have 2 horns or only 1?
Old Aug 19, 2014 | 01:27 PM
John A. Marker's Avatar
John A. Marker
There is a second fuse behind the panel in the center of the dash above the radio. First check the fuse panel on the dash behind the passenger side door. Then the inline fuse center dash.
You can always run a hot wire directly from the battery to the horns to test. From memory there are two horns......one each side.
Old Aug 20, 2014 | 02:31 PM
playsdixie's Avatar
playsdixie
there are two horns....on a 85 ....if you get them to work, a popcorn fart will be louder....replace them with a A and C tone horn set....any parts store has them....
To 85 horn problem
