windshield
Old Sep 5, 2014 | 09:41 AM
timstl's Avatar
timstl
Default windshield
Just purchased 96 collector edition, had to have water pump and optispark replaced (knew this up front). Only 83K, everything is good, however there is a small l shaped crack in top left of windshied prev owner had repaired does not leak no real issue, however if I want to replace this in the future what does a replacement windshield run?
Old Sep 5, 2014 | 12:45 PM
cigr's Avatar
cigr
I'm considering replacing the windshield in my '85 because the glass is rather old and has a ton of scratches making it look cloudy.
I got a quote from Safelite for $270 installed. I'm believe the glass is the same for all c4's.
Keep in mind you may need to replace your weatherstripping when you get the glass swapped out.
Old Sep 5, 2014 | 01:19 PM
RollaMo-LT4's Avatar
RollaMo-LT4
St. Jude 15 Year Donor
2021 C4 of the Year - Unmodified Finalist
St. Jude Donor '10 thru '25
Do a few searches on here for windshield replacement.
Very important to make sure whoever you choose has done a C4 before.
These older cars are not like the modern ones, and some of that windshield molding is very fragile and hard to come by if they damage it.
There are a few horror stories over the years about this.
Old Sep 5, 2014 | 01:39 PM
stingray71's Avatar
stingray71
I was considering purchasing a C4 that needed a new windshield so I called a auto glass shop that does a lot of C4s to get a ballpark estimate.
Where the glass would be about $325, the cost could skyrocket if the weatherstrip and mouldings needed to be replaced. Somewhere between $900 - $1300.
To windshield
