C4 coil removal
Old Sep 9, 2014 | 10:15 AM
oldtimer's Avatar
oldtimer
Default C4 coil removal
I feel like areal DUMMY .. Where are the screws ,nuts that remove the coil on my 1992 LT1 engine C4 has 108,000 miles. The instruction I read online say remove the screw and mounting nut. For some reason cant locate feel real dumb HELP Thanks
Old Sep 9, 2014 | 10:33 AM
WVZR-1's Avatar
WVZR-1
Originally Posted by oldtimer
I feel like areal DUMMY .. Where are the screws ,nuts that remove the coil on my C4 t has 108,000 miles. The instruction I read online say remove the screw and mounting nut. For some reason cant locate feel real dumb HELP Thanks
Coil is shown bolted to RH cylinder head in this image. LT1/4
http://thomas-chevy-c4.blogspot.com/...hats-done.html
It's assembled similarly to this. Don't forget heat sink paste if you disassemble completely:
http://parts.nalleygmc.com/showAssem...=0&modelYear=0
Old Sep 9, 2014 | 12:04 PM
zr1fred's Avatar
zr1fred
Veteran: Marine Corps
Unless the engine is NOT an LT. The 84-91 engines have the coil in the distributer cap.
Old Sep 9, 2014 | 03:11 PM
WVZR-1's Avatar
WVZR-1
With the year not posted and the "avatar" used by the OP I just went with it. Some just don't seem to get it". Maybe the "avatar" is only his "dream car"! We'll maybe find out. He!! it could be the "neighbors"!
Old Sep 9, 2014 | 03:13 PM
oldtimer's Avatar
oldtimer
At times wish I had my 80 Vette back it as much easier to work on.. much easier.
Old Sep 9, 2014 | 03:26 PM
RollaMo-LT4's Avatar
RollaMo-LT4
St. Jude 15 Year Donor
2021 C4 of the Year - Unmodified Finalist
St. Jude Donor '10 thru '25
Would also be much easier for members to help you, if you would always post the year of the car your asking about.
The C4 ran from 1984 through 1996.
Quite a few changes over the years, with 5 different engines.
Old Sep 9, 2014 | 06:03 PM
oldtimer's Avatar
oldtimer
Default 1992bvette
[QUOTE=RollaMo-LT4;1587792984]Would also be much easier for members to help you, if you would always post the year of the car your asking about.
Quite a few changes over the years, with 5 different engines.[/riQUOTE] right brain fade here 1992 Vette with LT1 engine
Old Sep 9, 2014 | 06:06 PM
oldtimer's Avatar
oldtimer
Default lt1
It's a 1992 with the LT1 engine
Old Sep 9, 2014 | 07:34 PM
oldtimer's Avatar
oldtimer
Default What
IT is my Vette FELLA not my neighbors !!
To C4 coil removal
