85 c4
by the way...welome aboard...lots of very knowledgable guys here with 85's.....
The only thing that should flash is the "check engine light" in the information display.
No i do know from experience "you must disconnect the battery charger before trying to start the car" it fried my ECM when i did that.
It would crank but ran verry rough and was not drivable just a bad idle.
There is a starter interupt relay "behind the information display" that has the check engine light, I would go thru the basics first.
Lock the door via the lock/unlock switch buttons, then close the door.
Now use the key and unlock the door and put the car in Park "wiggle it and try to start the engine. The car will only start if the Auto trans selector is in neutral or park.
Does your dash turn on? when the trying to start the car?
The ignition switch is on the steering column under the dash, there are two screws that hold it in place. if they are loose the ignition switch may not power the dash or the starter (via the starter interupt relay of course)
If your dash lights up when ignition is turned on the problem may be with the starter interupt relay (if the door lock is not used to open the door after activating the security door locks) or auto trans is not in Park.
Do you hear any clicking? your starter motor may have a bad solenoid?
Of course try disconnecting the battery for a few seconds and reconnect and see if that fixes your problem.
Should be a bad theft deterent relay/starter interupt relay/ ignition switch/ auto trans not set to park/ bad starter motor.
The diagram below may be of help
Good luck should be something simple (unless you tried starting the car with battery charger connected) then you will need a ECM
