93 cdm
Old Sep 19, 2014 | 07:22 PM
91coupe's Avatar
91coupe
Default 93 cdm
will a cdm from a 93 work in my 91
mine is shot and would like to replace
it and have mine fixed after
thanks
Rich
Old Sep 19, 2014 | 07:39 PM
bogus's Avatar
bogus
cdm? Is this the radio receiver module, or the module under the radio, the CCM, that translates things for the ABS and the ECM and stuff?
If it's the radio part, should work, no problem.
If it's the CCM, no chance in hell. The CCM also stores mileage. Buying a new one, you get 100 miles to have the ODO set by a dealer. After 100 miles, the CCM locks and is unchangeable.
Old Sep 19, 2014 | 09:09 PM
WVZR-1's Avatar
WVZR-1
What was it that "confused you"? The OP mentioned CDM and nothing else. As a matter of fact he mentioned it "twice".
OP - the CDM from the '93 will work. It would be an unusual set of circumstances that it wouldn't but if you had concerns you could confirm an exact match from the label on the CDM. If you're buying a CDM from an "unknown" seller it would be wise to check that information because remote receivers were used by many GM's other than Corvettes. Have you had the "hands on" of the '93 CDM?
It's nearly always assumed that the discussion is regarding a Bose unit. Is it?
To 93 cdm
