Rough Accelleration
Old Oct 6, 2014 | 12:38 PM
newbie2vette's Avatar
newbie2vette
Default Rough Accelleration
So I finanlly found the pin hole leak on my 1992, it was the heater hose mounted close the upper radiator hose. It was just past the fitting where the hose is mounted, so I decided just to cut the hose there and let the fluid run down so I can remove the remaind small part on the fitting. No leaks, but the accelleration is rough. I read many post about not getting the optispark. That's after I did what I did.
So what got wet and how does one fix it or dry what got wet? Better yet what got that cause the rough accel? Thank you.
