On my 85 vette I have the original cat on there. I'm assuming it's clogged up and I was wondering on what type of performance increase that I would gain if I just took them off or cut them open... Thanks in advance!
I don't have a cat on my 85. Antique plates so it's legal in my state. I have true duel outlets on each mufffler. In other words, both outlets on each muffler are open. It's not loud at all. But it does sound much better and deeper than stock. I would estimate another 10 hp without the cat and an additional 10 hp with true duel exhaust.
Reason: typo
I haven't gotten around to messing with the cat on my '85 yet, but I can share what I know about the Monte SS (almost identical exhaust system).
it is a remarkably high flowing design, so if it's intact there won't be a big difference. 10-15hp is anout right, about like a/c con vs off.
If the case has any serious dings in it, the "tunnels" will be shifted and therefore blocked off and you could see a big improvement over what you currently have.
Rather than cutting it out, just remove it and bust the innards out. It'll have a nice muscular tone and will be easy to put back a good one if the need arises.
You only have to actually remove 2 bolts on each end, the others are slotted.
I had an '84 and '88 Monte SS and one good convertor that I would stick on just for inspection day.
Thanks for all the info guys! I was thinking of pulling a red neck move and just cutting them open, removing the guts, and then sealing it back again with jb weld. I dont think those 30 year old bolts are going to be easy to take off at all so that will be sort of a back up plan...
Also, is it difficult to remove the a/c unit? If that'll free up another 10 or so hp that would be great!
Just because they don't do emissions testing in your state, does not make it "legal" to remove your catalytic converter.
There are Federal laws about tampering with any factory emissions equipment.
Now with that said, the chances of you being caught or fined for it are slim.
But a muffler shop could get in real deep trouble doing stuff like that.
This is the exhaust I installed on my '84. There are some fitment issues that needed to be handled by a local exhaust shop. But they do sound great once everything is set.
Also technically anything louder then the stock exhaust installed on the car is illegal. Louder options don't count unless the car in question had that option.
You normally don't see cars getting fined for exhaust noise unless it is over the db limit in that area.
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
Originally Posted by aklim
If it is badly clogged up enough, 240HP
I wouldn't just cut it off since it makes a lot more noise and the power difference between a good cat and none is negligible.
EXACTLY!
A gutted cat will only make the exhaust stink.
I found a good Magnaflow and the SOTP power didn't change.
OK, bad choice of wording. It's not what I meant. I don't have to get emissions tests done on a car with antique plates is what I meant. They're exempt in my state. I'm fairly sure everyone is familiar with the "federal Laws".
Removing the cat with a pipe or gutting the cat and putting it back on is a 9% gain in hp. Do it, it will be a little more snappy when you hit the go pedal.
I guess I should rephrase that...
It takes roughly 10 hp to drive the A/C compressor when it is active.
When it's disengaged, it uses almost nothing. Also, I believe these cars disengage the A/C under heavy throttle.
I guess it's a bad frame of reference in these days of cputer controlled throttle, but on a carb'd car there is slight bog when the compressor engages. Almost unnoticable. That's what 10hp feels like.
If it really takes 10 HP, don't turn it on when you want to race.
