Towing C4 to Shows ....
I'm looking to buy an Enclosed Car-Toy Trailer:
The H3 Alpha is rated at 6,000 total pulling weight capacity.
Tools, tires, food, beer, etc: 300 Pounds
Corvette: 3,500 Pounds
Enclosed Trailer: 4,000
Total = 7,800 Pounds
Unfortunately, I am obviously over the limit pulling with my H3. That said, I'm thinking about buying heavy duty Truck like the Dodge Ram 3500.
Dodge Ram:
Question: If you were me - what would you do?
Thanks in Advance all Valued Opinions.
My truck is a crew cab with an 8' bed and the longer the truck the better the tow. It has the Alison trans with engine brake which also really nice if you have to stop quickly or going down a long grade.
You can tow with a lesser, smaller, cheaper truck that is at its maximum tow rating but there is a big difference with a bigger truck. It's not just the power to pull something but the ability to stop and make evasive maneuvers. The last thing you want is to have your precious cargo upside down in a ditch because your tow rig was not sufficient.
I will tell you up front that no 1500 half ton or less truck is going to tow what you want. Sure the Chevy/GMC twins with the 6.2L and MAX tow package are rated at 12K but you are right up against the max limit from the start. Not a good plan. Not only that, you will spend more on a lesser truck to get it prepped to tow the weight than you would just buying an HD truck to start.
You need a minimum of a 3/4 and probably should be looking at a 1 ton. I will also say there is no such thing as cheap when you get to this weight class.
One other thing. Half ton trucks are focused today on fuel mileage. This means that when not towing they get great fuel mileage. As soon as you hook a trailer to them they go south quick in the mileage department. So that truck that gets 20ish MPG by itself is only going to get 7-10 MPG towing.
You really need to ask yourself how much you are going to tow and how often you will drive the truck unloaded. Do a lot of research in the towing forums and truck forums. Lots of decisions to make.
Having just gone through this myself, I can tell you there are many great choices and options on the HD trucks that just even last year didn't exist.
Not going to get into the Diesel vs. Gas debate here. I am just going to state facts as I know them.
CONs
1. Diesel initial buy in is $7-10K over a gasser.
2. Diesel maintenance is more than a gasser on a astronomical scale. Fuel filters/water separators, DEF, Gallons of oil vs. quarts of oil.
3. Diesel fuel (in my area) is 40-50 cents higher per gallon than gas.
PROs
1. Diesels get better fuel mileage when loaded. Highest I have seen is 5 MPG over a gasser with similar loads. 8 MPG on gasser (Dodge V10) vs. 13 MPG on Diesel (Ford 7.3L PS)
2. Diesels tend to run longer without major tear downs. 300,000 miles or better. However, I think the gassers are catching up these days.
You need to decide which one is better for you. In my case the diesel would not pay for itself so I bought a gasser.
with Joe..
.. I bought my car to drive, driving to the shows with friends is a big part of the fun for me.. That's why I have 162,000 miles on my 89...If I had to trailer my car to shows I wouldn't go..I think you'll also find using a trailer is a PITA, you can't just park it anywhere and getting the car on/off by yourself is a hassle...It always seems to me that the harder/more complicated you make things, the less fun you have.......Just my opinion...
....WW.
Where you tow will make a big difference in tow rig selection. If you go long distances and over big hills or mountain passes, certainly a 3/4 ton truck with a diesel is the best selection. I would suggest a Chevy or GMC with the DuraMax and Allison trans. Ford has a good package but some of their diesels will be expensive to service and parts can be very expensive. As far as brand "D", run, don't walk away...
Definitely get a tow rig with an extra tank if are going long distances.
with Joe..
....WW.
I've only taken my Vette to one Corvette only show and I drove it. I generally don't take a late model car to car shows. Unless it is highly modified I always found to odd to take a new car to a show (I consider C4's to be late model new cars). I feel that most people go to car shows to see some unusual, not something you can see anywhere.
That said, I drive my hot rods to shows. That is part of the experience is the trip there. As they say, "It's not the destination, it's the journey".
I've had countless interesting (and sometimes painful) conversations with people when driving a hot rod on the road. Stopping for gas, getting food, stopping at sites, etc. Everyone loves a hot rod! I really get a kick out of the older folks that ask about the car and tell me how they had one just like it way back when.
I've driven to nation events leaving home by myself and hitting the road amongst all the commuters drudging along on their way to work. Once clearing town the traffic clears up and you can roll on the miles in solitude, watching the landscape change as you travel farther from home. People waves, smile and give you a thumbs up as you pass by. Then up ahead you see one, the distinctive silhouette of a fender less chopped top 30's rod or maybe the rotund outline of a 40's fat fendered car. Could be a 60's muscle car or the low profile of a Vette.
Anyway, you smile and press on the gas just a little harder and as your heart rate increase in anticipation of what's up ahead. You catch up, pass and look over to check out the car with a smile and a big thumbs up which is returned. You fall back over to the slow lane and then it's the two of you running along across the great open road.
You both pull over to gas up and eagerly shoot the breeze about your cars, where you're from and what you do. But you got a long ways to go and a short time to get there so you saddle up and hit the road again. You're tooling along and then, three more cars are coming up the on ramp and joining in line. Then a few more come rolling up from behind just as you come up an a large group ahead. Obviously a car club as they are flying their plaques and banners. Pretty soon there is a line ahead of you so long you can't even see the lead car. You look in your mirror and the goes back the same. As far as you can see, bright colored rods, chrome sparkling in the sun, big fat tires and the sound of free flowing exhaust like music to your hears. Who needs a stereo when you can listen to the symphony of big and small block Chevy's, Hemi's and wedge motors, FE's and Cleavland's?
Once you get to the event city the cars start to peel off going to their respective hotels. You make a beeline to the host hotel so you can get your badges and goody bags before the lines get two long but it still takes you an hour because there are so many cool cars in the parking lot. Okay, I just have to check out this bitchin' Deuce coupe. Wait, look at that '67 427 Vette coupe there! Dang, look at that bad *** '55 Chevy gasser! A Henry J, a Boss 429 Mustang, a ******, they're rolling in faster than you can check them out!
Do you want to be the guy missing all the fun driving a pick up truck with your cool car in an enclosed trailer? Drive 'em if you got 'em!
Here's me driving my Model A while my buddy trailers his beautiful 392 Hemi '63 Dodge (I had way more fun).
Corvette
Fancy enclosed trailer
Towing vehicle
...so you can go to car shows.
What is that; $50,000 or more? Drive the 'Vette to car shows (or even better, the track!) and save $40k on the trailer and truck.
I drive my 147,778 mile C4 to shows.
They won't melt if it rains on the way. Just carry some detail spray in the trunk and some Clean microfiber and Terry cloths.
Now if you want to get a trailer, and truck for possible future projects which Can't be driven home (bad brakes, engine etc) that's different.
Around here, even with some serious custom cars, quite a few guys drive to shows.
My car isn't a showstopper by any means, but it gets mad respect like a few other cars, that I usually see around for being a daily warrior. For what it is, my car is Clean.
By the time you buy a truck, and trailer for this car and your other toy, you could have bought a used low miles C6 man.
If you want to take 2 cars to the show, just stop by a trusted friends house, ask him or her if they want to go to the show, and drive the other car. That's what I did when I needed to take multiple vehicles.
And they always appreciate the chance to drive a nice car
Appreciate for all the great feedback.
just one more reason why I won't get into a judged car show. crap like that takes all the fun out of it.
How did this turn into 12Klbs?
