C4 Engine Smoke
Old Oct 14, 2014 | 07:42 PM
rayou01's Avatar
rayou01
Default C4 Engine Smoke
I have a 93' Vette with 134k miles on it. It holds its own but when it hits 210-220 degrees on the engine temp on idle, it will randomly start smoking from the engine bay. I have also noticed that if I achieve and/or exceed 50 mph and then come to a stop at 210 degrees, it will start smoking. It looks more to be from the upper coolant reservoir. I have not flushed the coolant but have added 50/50 coolant to the upper and lower reservoir and have noticed a change in regular driving temp from 235 down to 220 but the car still smokes. What could it possibly be? Is the upper coolant reservoir cap maybe failing? Should I flush the whole cooling system? Does the 93' Vette maybe have a certain type of insulator that is used for the hoses that may be at fault? Hit me with as many possibilities it can be.
Thanks,
Ray
Old Oct 15, 2014 | 02:57 AM
enventr's Avatar
enventr
Regular driving temp should be approx 195-205. Check the front of radiator for debris ( leaves etc) . The coolant should be changed if it has not been done in awhile. I do not know about your smoking issue
Old Oct 15, 2014 | 03:02 AM
Cliff Harris's Avatar
Cliff Harris
The cap on the upper coolant reservoir might be leaking. I have heard of a reservoir that cracked and had your symptoms.
Old Oct 15, 2014 | 06:04 AM
Paul Workman's Avatar
Paul Workman
When my upper reservoir cap went bad, the lower over-flow bottle would remain filled when it cooled, and the upper reservoir would be low/dry. Replacing the pressure cap on the upper tank fixed it.
One other time I suspected a leak elsewhere, but couldn't narrow it down. AutoZone supplied a coolant temperature test kit that allowed me to pressurize the system and inspect all the connections while the engine was cool. (Turned out to be a bad hose connection.)
Once the hose clamp was dealt with, I was able to pressurize the system to 22 psi ( 7# above the point the 15# cap was rated) and observe the pressure held steady for the 15 minutes I conducted the test. No leaks seen or detected.
Note: I ended up purchasing the tester from AutoZone, which they will allow you to do, last time I checked.
Good luck!
Old Oct 15, 2014 | 06:32 AM
ricasso's Avatar
ricasso
Valve cover gasket leaking and opening up as it gets hot, oil dripping onto manifolds? is it oily smoke? have you lifted the hood while its running to see where it's coming from?
Old Oct 15, 2014 | 07:33 AM
davewhtt's Avatar
davewhtt
Smoke and steam are easy to tell apart,and one dosent smell like the other. An engine oil leak can happen more (sometimes) when it is hot also just like antifreeze leak.
Old Oct 15, 2014 | 10:53 AM
Paul Workman
To C4 Engine Smoke
