lights pulsating
Old Oct 15, 2014 | 10:03 AM
hughesm's Avatar
hughesm
Default lights pulsating
the interior and exterior lights just recently just started to pulse. makes no difference if step on the gas or not. they work fine but is annoying.any one have any thoughts on this. 1988 4+3 98000 miles.other the the lights the car runs great thanks for any info mike
Old Oct 15, 2014 | 11:06 AM
deptcruser's Avatar
deptcruser
Default lights
check the power coming from the alternator. Could be the voltage regulator is starting to go.
Old Oct 15, 2014 | 05:09 PM
cuengineer's Avatar
cuengineer
Sounds like either a failing charging circuit or a bad connection. If alternator checks out okay, you might want to check the grounds. A good cleaning might work wonders and always helpful to have good grounds to reduce other problems.
To lights pulsating
