Heater Controls Not Working
Just picked up a 1993 c4 and I noticed that the off button and the two next to it to the right stopped working. I cant regulate the temp in the car it seems to be stuck on 90 degrees. Any suggestions. I did see a youtube video on how to scan codes. Anybody ever have this issue.
John From Boston
John From Boston
John From Boston
John From Boston
John
I had the same problem. After cleaning the control head everything worked perfectly. Whole operation took less than an hour from start to finish.
This is the thread you want.
https://www.corvetteforum.com/forums/c4-general-discussion/1519199-climate-control-button-repair.html
I had the same problem on my '94. I cleaned the contacts (under an hour too) and from then on it worked perfectly.
Good luck
2018 C4 of Year Finalist
2021 C4 of the Year - Unmodified Finalist
St. Jude Donor '10 thru '25
Mine was that way also. It would work most of the time, but the times it wouldn't became more frequent.
It has worked 100% of the time, every time since I did the repair
