Winter Storage
Old Oct 15, 2014 | 07:23 PM
lloyd430's Avatar
lloyd430
Default Winter Storage
Just picked up my 1st 1993 c4.Getting ready to store it soon in Mass cold weather approaching. Garage is not heated im a little concerned about mice. Seen allot of ideas on how to keep them away from the car. Alway interested in more ideas. Also how much stabilzer do I add to a full tank.
Old Oct 15, 2014 | 08:29 PM
playsdixie's Avatar
playsdixie
grew up in rural michigan...we kept outside cats...kept the mice down...however, sliced and diced a few on cold mornings in the daily driver..
Old Oct 15, 2014 | 08:43 PM
MyOtherCar's Avatar
MyOtherCar
Veteran: Marine Corps
mothballs in a soda flat under the car seems to have helped although I do keep poison feeders and sticky traps throughout the pole barn.
Just fill it up with fuel, don't fret about the stabilizer.
Hook up your Battery Tender, toss on your Auto Chic or Covercraft cover and while away the winter.
If you think you need to start it during the winter lay-up, don't, unless you can get it out and drive it. It would be Important to get the trans and diff warmed up just like the engine, if you want to go that route.
Not necessary, it sat on transit and dealer lots for much of its life when new.
Old Oct 15, 2014 | 08:49 PM
lloyd430's Avatar
lloyd430
thanks what do you mean on soda flat under the car.
Sorry just want to get it straight.
I heard dryer sheets in the car and on the tire tops help what do you think about that idea.
Old Oct 15, 2014 | 09:15 PM
corgasm's Avatar
corgasm
Default storage
After having mice chew just about every small wire in my '92 some years ago (causing many $$ in repairs) the only foolproof protection (to me) is a car capsule. Even with that I still have glue traps, spring traps, moth *****, and Mouse-Away (peppermint leaves in a large tea bag). Dryer sheets lose their odor fairly quickly, rendering them useless. I've also heard of using urine soaked cat litter and coyote urine (predators). I admit it, I am obsessed beyond any rationality.
Old Oct 15, 2014 | 09:22 PM
lloyd430's Avatar
lloyd430
Thanks just seeking all avenues
Old Oct 15, 2014 | 09:33 PM
jv9999's Avatar
jv9999
I live in MA too. I don't have mice in my shop, but I do in my shed. Some swear by the electronic pest chaser things. In my shed I put out several tubs of poison, that seems to keep them from being a problem for long. I put stabil in a full tank, put a battery maintainer on it, and cover it. I have a few classics and I've never had a problem in the spring.
Old Oct 15, 2014 | 10:00 PM
lloyd430's Avatar
lloyd430
Thanks how much stabilizer in a full tank do you recommend.
Old Oct 15, 2014 | 10:14 PM
jv9999's Avatar
jv9999
Whatever the bottle recommendation is. I think it's 1 OZ per 2.5 gals.
Old Oct 15, 2014 | 11:51 PM
Tommycourt's Avatar
Tommycourt
There is an electronic device that will keep animals away from your barn, shed, garage, whatever you may have. I don't remember the name exactly but in Ca they use it to keep seagulls away from restaurants. The unit sells for about $600.00 and will keep a 3000 sq. ft area clear of rodents. They also have bigger units for bigger facilities. I think the name of it is "Pest Rid" or something like that. You can google it for getting rid of pests and it will come up. Unit is complete with sender and 3 receivers.
Tommy
Old Oct 16, 2014 | 12:24 AM
3JsVette's Avatar
3JsVette
Bounce in particular. I and many of my friends have used it inside the car with great success. Moth ***** inside a stocking seem to do a good job under the hood as well.
Old Oct 16, 2014 | 12:40 AM
MyOtherCar's Avatar
MyOtherCar
A soda flat (to me) is the cardboard box that a case of canned cokes comes in. Low sides, but great for dumping in some moth ***** and sliding it under the car w/o making a mess.
Other post about dryer sheets is true, they lose their aroma pretty quick.
I stored my cars while wintering in CT for the 10 years I lived there. Biggest problem was keeping moisture under control when Spring started coming around. Winter would thaw all day and then everything would refreeze at night.
Old Oct 16, 2014 | 04:38 AM
Lloyd Smale's Avatar
Lloyd Smale
for the 3 months your going to store it stablizer isnt nessisary. If your going to put it away for more then a year id look at using it though. I just wash and clean it good hook up a batery tender and cover it. I like to start my stored vehicles a couple times during the winter to keep seals from drying out. I even run the ac for a few minutes for the same reason. as to mice ive tried moth ***** and they didnt help. I put sticky traps all around and inside the car if theres mice and check them when i start the car.
Old Oct 16, 2014 | 07:52 AM
Cruisinfanatic's Avatar
Cruisinfanatic
From: Clifton Park, NY ............Clearwater, FL ... 85 Original Owner
After trying all of the above and still having mice camp out in my car for the winter, I used Fresh Cab the last few years and had no problem. You could see a few droppings, but they didn't stay which is Ideal. No dead mice in your car from poison.
Old Oct 16, 2014 | 01:54 PM
Scottys78's Avatar
Scottys78
Get an electronic pest chaser that you plug into an outlet. It worked for me, five years pest free
Old Oct 17, 2014 | 06:59 AM
WW7's Avatar
WW7
Here's a great little item someone invented......WW
Old Oct 17, 2014 | 09:08 AM
RIPJWB's Avatar
RIPJWB
I hate dem meeses to pieces! Thanks buddy! now you have me paranoid about mice as well.
To Winter Storage
Old Oct 17, 2014 | 09:56 AM
Churchkey's Avatar
Churchkey
Home made mouse trap:
Old Oct 17, 2014 | 11:50 AM
RIPJWB's Avatar
RIPJWB
Originally Posted by Churchkey
That is cool.. The best part is how patient the man is with his son while making the trap. (assuming dad/son)
You could keep the mice live and release them by your neighbor's house that has the Mustang.
Old Oct 17, 2014 | 12:50 PM
Rockcrushervette's Avatar
Rockcrushervette
Sounds like a lot of work must suck to have to park a car for winter !
