In this picture there is a threaded hole at the very top, above the rubber hose. The distributor clamp bolt goes in that hole (not the one on the EGR tube -- that's for the EGR temperature switch):
Sorry to bring this subject back up but still can't seem to find the God damn est cable...I'm looking for a tan and blak wire coming out near the brake booster correct?
It should be closer to the wiper motor. It will be a single wire with a weatherpak plug to connect the wire. You unplug the weatherpak plug and then check your timing. Unplugging the wire will set a code 44 in the computer. Once you check and/or set your timing then plug the wire back together and disconnect the NEGATIVE battery terminal for about 5 minutes. This will erase all stored codes in the computer.
