How to remove paint oxidation?
Old Nov 2, 2014 | 12:50 PM
corvettesforevor's Avatar
corvettesforevor
Default How to remove paint oxidation?
the top part of my rear bumper on my red c4 is oxidized. The red has patches of rough oxidized whitish patches. I washed the car and tried using rubbing compound. The paint looks like it magically is fixed when I rub it in, but as soon as it dries and I rub it off it goes back to looking oxidized. I even bought this special liquid that's supposed to help, and it does, but when it dries it goes back to normal like the last time. What can I do to get my paint looking good again?
Old Nov 2, 2014 | 01:52 PM
DinoBob's Avatar
DinoBob
Very little, really. It looks ok when you rub the product in because it is filling in the microscopic flaws and damage which is reflecting light and making it appear whitish.
If there is a lot of "meat" left to the clear you may be able to wetsand and carefully machine polish. But it's a longshot. Or you could carefully sand the clear and respray some clear over it. This may help.
Is the car garaged or covered?
Old Nov 2, 2014 | 08:38 PM
Patsgarage's Avatar
Patsgarage
My 89 has the same problem, short of a respray there is not much that you can do. If it is just on the bumper cover, I had mine resprayed last year for around $500. The decklid is getting pretty bad as well, but the car is not garaged, and I can't see it from the drivers seat !
Old Nov 3, 2014 | 01:22 AM
ANTI VENOM's Avatar
ANTI VENOM
Sorry to say that you are probably screwed. My front bumper had the same symptoms. No buffing would help it. The clear is "dead". Best of luck
Old Nov 3, 2014 | 02:44 AM
Cliff Harris's Avatar
Cliff Harris
It's not the paint that is oxidized. Your clear coat has gone bad. The only way to fix it is to repaint the car.
Old Nov 4, 2014 | 01:16 PM
ch@0s's Avatar
ch@0s
GL
Old Nov 5, 2014 | 11:46 PM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
We tested the hood where the clear was peeling.
Touched the base coat with 400 grit and nothing could help it.
Tried to clear coat and it was better off looking like leprosy.
& GL
Old Nov 6, 2014 | 07:16 AM
Paul Workman's Avatar
Paul Workman
I know squat about paint, so take it from there. But! As a casual observer, it occurs to me the clear coats are beautiful...up to the point they break down. Then...forgetaboutit! Nothing but a repaint will do.
However, BMW (and some others?) have moved away from clear coats in favor of a new (for lack of better words) "all in one" polymer (?) paint from PPG.
Brett put me onto it last spring when I had my car painted, and maybe all quality paints look good new, but this paint came out absolutely stunning, and it is suppose to be more durable than the color/clear regime currently "in Vogue" (including the C7s). Time (and sun) will tell. But, from here, it looks very good, and it is a ONE STEP paint process: NO clear coat.
I would think that if you removed the bumper cover and prepped it yourself, so that all the shop had to do was spray it, you could get by a lot cheaper. Color matching...would be a question tho... As others have said, the whole car might (as well) need to be painted. ($5k IF you disassembles and prime it yourself first, and the put it back together...)
To How to remove paint oxidation?
