89 Corvette- Head Lights will not open
Old Nov 7, 2014 | 12:19 PM
Ferrante's Avatar
Ferrante
3rd Gear
Default 89 Corvette- Head Lights will not open
Need Help- Head lights will not open completely nor can you manually open them- when I disengage the head light switch on my dash one closes the other one half closes- you can hear the motor assembly running. Under the hood I can visually see two small canister units with a small cap (that you can manually turn) mounted adjacent to each headlight- Any suggestions to 1) get them both to shut or open manually in an emergency 2) what I need to do to fix them correctly.
Old Nov 7, 2014 | 08:13 PM
Rockcrushervette's Avatar
Rockcrushervette
I lost a gear on one side disconneted motor wires garbed the light frame while twisting the manual control I pulled on light till it past were gear was stripped was able to get it all the way up and it just stayed up since wires were unhooked! The other light would work with switch! Ordered the gear easy rebuild on that think 30 min and 2 SHOTZ Vodka!!
Old Nov 8, 2014 | 02:59 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
If the gears & bushings are ok you should be able to slowly fully raise the one; the other sounds like bushings are gone to powder.
When trying the manual **** be patient as it takes many turns to see any movement of the HL.
If/when you decide to rebuild here's a link to a very nice pictoral procedure.
To 89 Corvette- Head Lights will not open
