Just did a leak test on my 93 LT1, and 2 leaked. But one leaked a lot. Anyways, what injectors do you guys recommend I get? To my knowledge, the car has the original Multecs on it. It's odd they leaked, as my car has just reached 78k miles.
Talk to Jon at FIC to make you get the right one's for the '93. When I bought my car the previous owner had installed the wrong ones, and Jon sent me out the correct ones. Excellent service.
How about helping the guy out by linking to FIC's web site? "Call Jon at FIC" isn't useful if you don't supply a telephone number. There is also a business called Fuel Injector Clinic, so "FIC" doesn't necessarily give enough information either.
Response to cliff. I have the fours in my car as I was trying them several years ago but put the threes back in. When I blew the head gaskets, ended up replacing the engine with another stock engine with just over 32000 miles which had the multecs in. I took them out and put the bosch 4 's in. The three's did not require the clip to hold them in place, but the four's will so the will be held in place and not leak. I didn't know that when I had installed them in my other engine, the reason why I took them back out. You will need a short extension wire as the wiring is a little short to clip onto each injector. Jon made a set of those for me at no charge. I'll try and send a picture. Just got out of the hospital in rehab so not doing too much. Sorry about not linking you to Jon.
Jon recommended that but have not done it yet. I've wanted to do that myself, but need some help. I do have the moates equipment and software. Just not a computer geek to do it. Hopefully next spring.
