O2 sensor position
Old Nov 13, 2014 | 06:42 PM
Mike1985's Avatar
Mike1985
Default O2 sensor position
Thinking of gutting the cat on my car since I don't have emission testing... is the O2 sensor pre cat or post? Would gutting it put codes on the computer?
Old Nov 13, 2014 | 06:56 PM
John A. Marker's Avatar
John A. Marker
You will not get a code. The O2 is on the front "Y" driver's side about a foot down from the exhaust manifold. Only one sensor.
Old Nov 13, 2014 | 06:58 PM
c4cruiser's Avatar
c4cruiser
What year? On my '87 the O2 sensor is (was!) just located below where the driver's side exhaust pipe attaches to the bottom of the exhaust manifold, and was easily visible. When I installed headers, I just moved the O2 sensor to the driver's side reducer. Bought a bung and welded it to the reducer. The wire was long enough to easily reach the new location. No codes either.
Gutting/removal of the cat will not set any codes. But why not remove the factory cat and replace with a aftermarket high-flow cat? Helps with cleaning the exhaust gasses and the high-flow versions won't hurt the airflow. Removing the AIR pump and tubing won't set any codes either.
Old Nov 13, 2014 | 08:05 PM
Mike1985's Avatar
Mike1985
what would removing the air pump and tubing help with?
Old Nov 13, 2014 | 08:06 PM
Mike1985's Avatar
Mike1985
Thank you
Old Nov 13, 2014 | 09:27 PM
corvetteronw's Avatar
corvetteronw
Cruise-In VII Veteran
Cruise-In VIII
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
It gets rid of all the junk on the front of you engine. Allows you better access to the front of the engine and enables you to clean that area very well. Before:
After:
Old Nov 13, 2014 | 10:20 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Allows you better access to the front of the engine ...
And it allows easier access to #2 & #4 spark plugs.
To O2 sensor position
