84 tps issue
Old Nov 14, 2014 | 07:27 AM
dads84vette's Avatar
dads84vette
Cruising
Default 84 tps issue
Greetings all~
My dads 84 has an unusual tps issue. The tps has high volts at idle and the low volts at wot. We know good old bubba has had his hands on the wiring under the hood. Question is, what would cause backwards readings, wiring? Ecu? Or? We have replaced the tps both with a dealer replacement and one from eklers. I have searched and searched to no avail. Any help would be greatly appreciated!
Old Nov 14, 2014 | 10:29 AM
corvettenorway's Avatar
corvettenorway
Originally Posted by dads84vette
Greetings all~
http://repairguide.autozone.com/znet...52800835ee.gif
Old Nov 14, 2014 | 10:34 AM
corvettenorway
http://www.pcfred.com/Vettetip/ECM%20troublecodes.htm
Old Nov 14, 2014 | 01:28 PM
dads84vette
Cruising
Thanks for the replies. But i think my lack of coffee made me word my question wrong. We get 4.5 volts at idle and .45 at WOT. The tps is going backwards. I have looked over the schematics numerous times and i am stumped.
Old Nov 14, 2014 | 03:53 PM
corvettenorway
http://corvette.stealing-fire.com/tps_diagnostics.htm try change wire a and c
Old Nov 15, 2014 | 01:44 AM
Cliff Harris's Avatar
Cliff Harris
One of your meter probes is on the wrong pin of the TPS. The black wire is the ground reference from the ECM. You should be measuring between the center wire and the black wire.
Don't put the ground probe on a random hunk of engine metal because the connection will not give a good reference.
I like this diagram better than the one in the previously-linked article (it has wire colors -- I don't think they changed over the years, but you can never be sure):
To 84 tps issue
