Exhaust Wrap
1. What is it's main purpose?
2. Is it necessary?
3. Can it only be used on exhaust headers?
4. Can it be used on exhaust pipes?
5. What would happen if I were to wrap my whole exhaust pipe, from cats to tips, with it?
Thanks guys,
Ray.
2. Is it necessary?
Thanks guys,
Ray.
Some say exhaust velocity is assisted by way of sustaining more of the heat in the exhaust gasses. (Technically is true, but to what significant effect is debatable)
Some or all of the exhaust can be wrapped, I suppose.
Ceramic coatings are (more or less) as effective, and esthetically are much better.
Depending on air flow around them and proximity to floorboards, for example, either wrapping or coating the headers/exhaust tubing and/or installing some insulation between the exhaust system and the cabin will control the heat (and to a lesser extent, quiet the exhaust noise inside the cabin too).
To each his own. I have uninsulated headers now and on many cars in the past. With exception of some barrier insulation shielding between the pipes and the foot-well, I've never felt the need to insulate the headers.
FWIW, Paul.
Generally, Exhaust Wrap is used to keep heat in the exhaust and out of the engine bay. It is also, used for looks on exposed exhaust parts such as on motorcycle engines.
1- there was a seat-of-the-pants changed, due, I surmise due to improved thermal efficiency (scavenging).
2- while residing in a quite corrosion-free climate, I also used the ThermoTech wrap paint which is not easily sourced, while the wrap is. This eliminated the water soaking issue, increased the life of the wrap and its adhesion. I found it at an aircraft supply store, and it's not cheap.
3- I greatly prefer ceramic coating, for appearance, clearance of header bolts and overall ease of installation. I'll never install headers without it. The wrap is intended to keep contain the heat, improving the efficiency, as above, but may not look great long term.
Using it further back in the system may help reduce cabin heat but I'd expect little performance gain.
FWIW, Paul.
Thank you,
Ray!
On my corvette I used an insulating blanket that covers the top half of the exhaust pipe and is held on with worm clamps and when properly installed, allows some air space between the pipe and the blanket. My main reason was to provide some insulation / heat protection for the rear fiberglass spring.
Yes you can wrap your headers with the exhaust wrap, however i advise against it.
Here is my experience, new headers a couple of years ago, was the plain painted type. The heat was shocking in the engine bay and floor of the cabin, i spent a lot on header wrap and wrapped the headers to the CAT. I would not recommend wrapping around the cat...
After a year and a half i started getting some leaks in the headers, i had to put patches on because the headers had gotten real thin due to the extreme heat it just destroys the headers.
Six months later they were trash i could poke holes in the headers with my fingers.
Now another new set of headers...$$$....
Beautiful shiny Hedman HTC coated headers, will see how long they last.
My vette is not standard, being supercharged so there is more heat than standard. It is common knowlege that header wrap really shortens the life of the headers.
It was nice and cool in the engine bay and cabin floor.
http://www.summitracing.com/parts/he...make/chevrolet
Thanks man,
Ray!
Thanks man,
Ray!
Like Paul said, it does helps to calm the drone (if you have magnaflow)down.
