Lifting an engine
Will a regular crane-type engine hoist be able to get an engine out of the bed of a truck? If not, it sounds like a regular chain hoist from the rafters is my best bet?
Once I get it out of the back of the truck, I'll have to pull my engine and install the new one in my C4. I'm not quite sure how to hook the engine up to the hoist to do so. One common method I've been able to find is: attach a chain from the rear of one head to the rear of the other using grade 8 bolts and washers, and do the same with the front, then hook up both chains to a load leveler on the hoist. Does that sound right?
I'm trying to figure out what equipment I'll need, and here's what I have so far:
- Engine hoist
- Load leveler
- 4 grade 8 bolts (not sure how long) and washers
- 2 short sections of chain
- Engine stand for when I pull my old engine
One last thing - what does a SBC long block with aluminum heads and an aluminum intake base weigh? I heard 500 lbs. or so?
Thanks in advance guys.
As long as you have the height/reach, you should be fine. This is my LT5, sans injector housings and plenum ≈ 25#, suspended from a Harbor Freight engine hoist.
I lifted an engine like that from the bed of my 4x4 F150 Ford PU, but w/o the leveler or the engine stand. So, depending on the combined height, lifting from your PU is the only unknown. You might have to loose the leveler and shorten the chains, etc, or revert to the chain hoist. (Provided the rafters will support the weight!!!
) Your estimate of 500# might be a tad high, but assume it is, and allow for it, and you should be fine. For example, I've often pulled long-block SBCs WITH an AUTO TRANS attached. With your 4-point attachment, you're good there too.
Good luck.
The leveler in the picture is a good addon if you can get one. If you have to tip the engine a little along the way, it's a simple turn of a crank vs lowering the engine and rechaining it. It will save headaches and scraped knuckles IMO.
Also look at the legs and rollers on the engine hoist and how they're layed out. I've seen a couple of designs that looked great and worked as well on trucks due to the wide width of the tires but contacted things when used on cars.
Just a couple of thoughts.
Question #2: It will weigh less than 500 pounds.
Most stands are 36" tall. So if you figure 36" plus the skid height of 5" and most pickup beds are 32-36 inches.....your engine is 6 feet off the ground when you bring it home. Then you still have to hook up a chain or something adding another 6" (or much more)...just not use if a hoist will lift that tall. Are the rafters in the garage strong enough to hold the 500 pounds of engine????
If the engine is on the stand, the freight company where you pick it up should have a fork lift. See if they can pick up the engine (bring some chain and place it on the skid. Bring some extra wood to prop it up on the skid.
Do you have plenty of straps to strap thins into the pickup if it is actually on the stand? I would not want to go aroung a corner with 500 pounds on a stand 3 feet off the bed.
That's a good point--I would not feel safe having the engine 3 feet off the bed of the truck.
If I end up lifting it from the rafters I'll put a peeler core or something across several rafters, which will distribute the load enough to safely lift the engine.
So have them lift the engine, then remove the stand and set the engine back on the palate?
Pic of that LT5 brings back memories. Myself and 2 other guys figured we didnt need a cherry picker to get one on the back of my truck. Let me tell ya that thing was HEAVY! The kind of heavy where once you had it picked up it was impossible to put down youd have to drop it.
Got it up to the tailgate and the pan hung up I dont know how it didnt drop;my hands were slipping off it started tilting over and backwards- someone coulda got seriously hurt.
One big heavy hunk of aluminum
Pic of that LT5 brings back memories. Myself and 2 other guys figured we didnt need a cherry picker to get one on the back of my truck. Let me tell ya that thing was HEAVY! Got it up to the tailgate and the pan hung up I dont know how it didnt drop;my hands were slipping off it started tilting over and backwards- someone coulda got seriously hurt.
Yeah, I decided against the route of "man up and lift it by hand"
Although I had a similar experience the other day with a huge hunk of concrete.
You might need help centering the engine when installing and doing some pushing and shifting, but it can be done.
Tommy
