LT-4 Question
Old Nov 20, 2014 | 09:34 AM
dtana's Avatar
dtana
Default LT-4 Question
I know that all LT-4s came with a 6 speed stick. Other than that, did LT-4s come as part of a "package" or was it an engine that could be ordered with any '96 as long as it was a stick?
Old Nov 20, 2014 | 09:38 AM
kimmer's Avatar
kimmer
C4 of the Year Finalist
If it was a 96 6speed it was a LT-4, if it was an auto it was a LT-1. Then there was the GS which had the LT-4 and a 6 speed. Hope this helps you .
Old Nov 20, 2014 | 09:47 AM
dtana's Avatar
dtana
Did all LT-4 equipped cars come with FX-3 suspension??
Old Nov 20, 2014 | 09:48 AM
RollaMo-LT4's Avatar
RollaMo-LT4
St. Jude 15 Year Donor
2021 C4 of the Year - Unmodified Finalist
St. Jude Donor '10 thru '25
It wasn't a "package". It was an engine option only.
The LT4 engine option "required" you to also order the 6-speed manual.
They were together, you couldn't get one without the other.
And yes, you could get the LT4 engine option on any '96.
And as kimmer noted, the GS only came with the LT4
Some believe that the Collector Edition only had the LT4 too.
But, you could get that model in either LT1 (automatic) or LT4 (manual).
Old Nov 20, 2014 | 09:49 AM
RollaMo-LT4
No
That was a suspension option. Had nothing to do with being an LT4.
You could get that option on either engine.
My LT4 has the base suspension.
Old Nov 20, 2014 | 10:48 AM
dtana's Avatar
dtana
Thanks for your help everyone.
Old Nov 20, 2014 | 06:45 PM
wfd1739's Avatar
wfd1739
You had 3 different suspension options.
1. FE1 base suspension
2. FX3 adjustable
3. Z51 stiffer performance
Old Nov 21, 2014 | 06:14 AM
Paul Workman's Avatar
Paul Workman
2. FX3 adjustable
I've always thought Keith had the right idea for a GS...
The "ultimate" GS, wouldn't you think??
Old Nov 22, 2014 | 05:21 PM
wfd1739's Avatar
wfd1739
Old Nov 23, 2014 | 06:41 PM
96GS#007's Avatar
96GS#007
2. FX3 adjustable
FX3 was not available in 1996. It was replaced by F45. Same concept, different type of shock and control system.
Old Nov 23, 2014 | 06:43 PM
wfd1739's Avatar
wfd1739
You are correct. Thank you.
To LT-4 Question
