Gas tank
Old Nov 21, 2014 | 07:09 PM
bbwool42's Avatar
bbwool42
Default Gas tank
I have had much help with this forum with my 1996 C4 with various problems. I have had fuel line problems and have concerns that my gas tank may have rust. Is the C4 tank made of metal, plastic or fiberglass? Is there a way to clean out or see into the tank. Any help appreciated. Thanks
Old Nov 21, 2014 | 07:13 PM
383vett's Avatar
383vett
It's metal with a thick rubber bladder. You can access the tank by removing the bolts around the top of the filler area. Remove the hatch assembly and you will see the bolts. The fuel pump comes out with the tank top and you will be able to see directly into the bottom of the tank.
