need help please
Old Nov 22, 2014 | 09:33 AM
CrimsonRacing's Avatar
CrimsonRacing
Cruising
Default need help please
1994 LT1 Coupe
after installing a brand new optispark dizzy,harness and ecm,now the heat is not working(which did before).......ideas?
any input would be appreciated
Old Nov 22, 2014 | 11:25 AM
Silver96ce's Avatar
Silver96ce
Originally Posted by CrimsonRacing
1994 LT1 Coupe
When you say the "heat is not working" do you mean the HVAC system is blowing cold air? If so, check and make sure that you have gotten all air out of the system and that the hoses are attached to the correct locations. If the system is not turning on, check the fuses.
Old Nov 22, 2014 | 11:38 AM
CrimsonRacing
Cruising
Silver,
Yes....it is only blowing cold air sir.
Old Nov 22, 2014 | 01:06 PM
1993C4LT1's Avatar
1993C4LT1
Maybe a dumb question, but did you let the car warm up? Are all vacuum lines connected?
Old Nov 22, 2014 | 01:23 PM
CrimsonRacing
Cruising
car ran to operating temp......hoses are good and warm....only cold air coming thru vents....appears all vac lines are connected but I am thinking one might have been missed.
Old Nov 22, 2014 | 02:50 PM
auggy's Avatar
auggy
Is the car running hot or overheating?
Old Nov 22, 2014 | 03:04 PM
CrimsonRacing
Cruising
car is showing normal operating temperature.....
Old Nov 23, 2014 | 01:51 AM
Cliff Harris's Avatar
Cliff Harris
Are the heater hoses going into the firewall both hot?
There is a restrictor in one of the heater hoses. Sometimes trash builds up there and prevents the coolant from flowing through the heater core.
Old Nov 23, 2014 | 01:24 PM
desertmike1's Avatar
desertmike1
Warm is not good enough!
They should be Hot to a point that you can't leave your hand on them.
If their Warm then there is a restriction in the lines themselves or the heater core.
I would try a simple Heater Core back flush with a garden hose. This as helped many of us in the past.
To need help please
