Passed CA smog today !!!!!!!!!!!!!!!
Old Nov 26, 2014 | 09:12 PM
mcm95403's Avatar
mcm95403
Default Passed CA smog today !!!!!!!!!!!!!!!
I finally have the car all put back together so I got a temp permit and took it to get smogged. All the numbers were really low so it passed with flying colors. Man, I'm so happy to finally have it back on the road! Funny, the state lists the reason for inspection as "high emitter profile", even though it's just the usual bi-annual check to keep up your registration.
And for those who want to know the numbers:
test RPM %CO2 meas %O2 Meas HC Max HC Avg HC Meas CO Max CO Avg CO Meas NO max NO avg NO meas
15 1583 14.9 0.7 78 23 13 0.51 0.07 0.01 545 211 248
25 1430 14.9 0.7 61 19 9 0.42 0.06 0.01 502 189 463
Sorry, can't get the numbers to line up correctly.
Old Nov 26, 2014 | 09:57 PM
1993C4LT1's Avatar
1993C4LT1
Old Nov 27, 2014 | 01:41 AM
GKK's Avatar
GKK
Congrats!...
My 145k 91, just passed the California Emissions test too!!!...
Old Nov 27, 2014 | 02:43 AM
mcm95403's Avatar
mcm95403
Originally Posted by GKK
Congrats!...
With everything I've done to mine I was a little worried. VERY happy to see it so clean out the back.
Old Nov 27, 2014 | 11:13 AM
GKK's Avatar
GKK
My 91 is all Stock.
What mods have you done and what year?...
Old Nov 27, 2014 | 12:36 PM
mcm95403's Avatar
mcm95403
My 91 is all Stock.
Mine is also a 91. I've done a Super Ram, Fast Burn heads, LT-4 cam repro cam (with .480 list from the 1.52 Comp Cams roller tip rockers), LT-1 headers (with an EGR tube added), underdrive pulleys, Bosch injectors, mail order tune, Magnaflow catted y-pipe, and Flowmasters. Plus, a little bit higher stall converter, new trans, narrowed the rear end 1.1" to fit ZR-1 saw blades and 315's in the back, heim joint strut rods, poly bushings in the dog bones, and have a VB&P 32mm front sway bar and a stock 24MM rear bar with poly bushings, 84 Z51 springs front and rear, plus Koni shocks and also did a C5 front brake conversion. All of that is wrapped up in a nice Turquoise Metallic shell.
Old Nov 27, 2014 | 01:38 PM
GKK's Avatar
GKK
Do the Heads have an EO #?...If not, you got lucky they didn't ask about it on the visual!...
Old Nov 27, 2014 | 02:12 PM
383vett's Avatar
383vett
Congratulations. I know from experience that a clean smog test is cause for celebration.
Old Nov 27, 2014 | 02:49 PM
3D87C4's Avatar
3D87C4
Old Nov 28, 2014 | 01:34 AM
mcm95403's Avatar
mcm95403
They're not any different looking than the stock aluminum heads.
He did say that the headers were "very pretty", and I "explained" that they were stock headers with the heat shields removed and then ceramic coated
Old Nov 28, 2014 | 11:31 AM
C4orce2's Avatar
C4orce2
Man oh Man, I feel so sorry for you guys!
Old Nov 30, 2014 | 02:28 PM
Dr.DoomsTPI's Avatar
Dr.DoomsTPI
Passing all in itself is cause for a celebration here in California. Great that you snuck those mods through and she's back on the road
Old Nov 30, 2014 | 07:50 PM
JD Shredds's Avatar
JD Shredds
Haha, that is one thing I don't miss about living in CA. Congrats on the pass! Even testing my DD (2.2L) tended to raise my blood pressure until it passed. Damn youse CA! Daaaamn youuuuse!
Old Nov 30, 2014 | 10:31 PM
kdf1986's Avatar
kdf1986
Congratulations on getting it to pass. I have a stock 86 and do not look forward to the biannual smog check. I only failed one time, and that was for the emission hose causing a large emission failure on their machine.
Nothing updated as drastic as yours, but its still cause for a mini celebration.
kdf
To Passed CA smog today !!!!!!!!!!!!!!!
