Battery Disconnect
Let me put your mind at ease. If your battery is healthy when you park it a battery disconnect is all you need. New batteries sit on shelves for months and work just Fine when finally installed. To remove the battery take the side panel off then it slides out I believe there are 3 10 mm bolts on the bottom and 3 or 4 torx screws on the front fender liner area. FYI I live in Wisconsin and my 93 has been parked for a month now with the battery connected just went out and fired her up Yesterday with no issue's my battery is only about a year old but it's just the cheapo Delco.
I was close to the point of cutting the panel before I finally got a wrench on it enough to loosen up the bolt.
Whoever did it made a stupid mistake and it was awful getting it loose when I went to change the battery.
Make sure that washer on the bottom bolt goes under the tab on the panel.
Yep, I can see that happening to me, but it won't because I'd have to remove it in the glow of a flash light, as there is no electricity in my storage shed.
R/C
R/C
I can give you one scenario that will make that happen. The previous person that pulled the panel you remove to take out the battery on my 86 slid the panel tab on the bottom between the washer and the head of the bolt then cranked it down. It dug into the tab and almost none of the head was accessible (no space between the panel and rocker to angle the wrench). I had a bear of a time getting a wrench on it to loosen it up. I must have spent over 30 minutes on that one bolt before I was able to get a wrench on the enough on the head of the bolt to loosen it up.
