Converting C4 to C6 Auto Shifter
Old Dec 3, 2014 | 11:33 AM
Hary Gahtoe's Avatar
Hary Gahtoe
Default Converting C4 to C6 Auto Shifter
Late model C6 shifter has a more ergonomic and up to date style shift ****. Parts are relatively easy to get and reasonably priced so I was interested to see if someone has it installed
Thanks for any replies
Old Dec 3, 2014 | 11:35 AM
aklim's Avatar
aklim
The C4 or 700R4 trans can be rebuilt to be pretty stout for a reasonable price. If you put he C6 trans in, what are you trying to achieve? Will the trans need a stand alone computer to make it work? What will you be willing to pay?
Old Dec 3, 2014 | 11:57 AM
GKK's Avatar
GKK
The Op is asking about installing a C6 shifter "****" in a C4 Vette not, installing the entire C6 transmission...
To the OP - Is this a manual or auto shift ****?...The C4 manual shift **** is secured with a metal wedge on top and the C6 manual shift **** is secured with a screw on the bottom left side.
The 2005 C6 auto shift **** has a similar look to the C4 auto shift **** but, not sure if it's secured the same way with a snap ring. The 2006 and up C6 auto shift ****, has a more rounded ergonomic contour and is secured with a plastic lock collar on the bottom of the ****. It's a little more involved but, it might be possible to use the 2006 C6 auto shift ****...
Old Dec 3, 2014 | 05:24 PM
Hary Gahtoe
The car is auto and my purpose is solely the shifter mechanism is tall (slightly cumbersome and not suited to my driving position) and if I re work the stalk I want the grip better fitting like a newer style C6.
I'm not concerned with any particular difference in parts, this is going to be a one- off arrangement and won't be just a parts swap which I know and that's all good. Just a query to see if anyone's done this already
Old Dec 3, 2014 | 05:36 PM
JackDidley's Avatar
JackDidley
05 C6 has a 4 speed automatic. 06 up, a 6 speed. I'd think the 05 would be doable. You would need the C4 cable since the C6 trans is at the rear of the car.
Old Dec 3, 2014 | 05:44 PM
Hary Gahtoe
Just so this isn't misunderstood. I'm only modifying the original C4 auto stalk, and replacing the handle with the late model C6 ****. I'll be adapting the C6 **** button to work the (modified) C4 stalk and trans cable.
Old Dec 3, 2014 | 09:45 PM
Roys92BlackRose's Avatar
Roys92BlackRose
I too am looking for a replacement shift *** (forum censors the word when spelled correctly??). I hate the push button on top. What were they thinking?
To Converting C4 to C6 Auto Shifter
