Tire/wheel size
Tire/wheel size
Okay, I'm a woman with my first corvette. It's a 95 LT1. I have noticed that my front and rear tires are the same size (275/40ZR17). I talked with someone yesterday and they said that there vette has 17 on the front and 18 on the rear. Is it just a personal preference or is there a reason for a larger wheel/tire on the rear??? Vikki
tire size
I believe that '95 SPID label location is in the rear storage compartment. There would be substantial information on that label that could be valuable to you in the future.
l on the rear tire/wheel package. Welcome to the forum,BTW, its the best corvette source for info on the net.
The 285/35 is very close in size to the 275/40 so it's possible the PO got a good deal on that particular size. There should be a sticker on the driver's door that shows the tire size that came on the car.
My 92 has C5 Z06 reps, 17 front, 18 rear. Looks great and no issues. I'm swapping out the wheels for C5 thinline OEM to save weight though (reps are nice looking but very heavy).
And those tires were not a "stock" size in '95. A previous owner changed them. In '95, only the ZR-1 had 315/35-17 tires in the rear and they were mounted on a 17x11 wheel.
Then I found some information on the stock wheels that are on it and I think the front wheel is 9.5" wide and the rear is 11" wide. Does that sound right?
I want to buy new wheels but keep the new tires that are on it.
This site rocks!!!! Vikki
Thanks for all the response, again. I found the sticker: Frt. P255/45-17 Rr. P285/40-17.
Okay, now this is a really dumb question. Can I find out how wide the wheels are without taking the tires off?
You should be able to. Nearly every wheel produced has the wheel dimensions cast into the back-side of them. You just need to remove a wheel/tire and see what is cast on the back-side. There should be no need to remove a tire from the wheel. Tire stores have wheel calipers also that can be used without removing the tire. It's generally required to remove the tire/wheel to use a wheel caliper also. It can be done without but it's aggravating sometimes.
If you want to get new wheels and keep the 275/40-17 tires just get four 17" X 9.5" wheels and you will be fine. I have them on my 96 CE LT1 from one of the vendors on this site.
T
T
Tires / wheels
