Passenger Door Light
Old Dec 7, 2014 | 08:10 AM
Retxpres's Avatar
Retxpres
Default Passenger Door Light
I had my passenger door window guide replaced over the summer. There is an electrical quick disconnect that goes to the door light. Do I need to remove the whole door panel or can this be reached by removing the trim around the door handle that opens the door? The car is a '94 coupe.
Old Dec 9, 2014 | 08:26 AM
davewhtt's Avatar
davewhtt
I have a 93 and i was able to reach the wire/clip and connect without removing door panel(again) You may have to make a wire hook to grab it though. Dave
Old Dec 9, 2014 | 01:32 PM
cormorant71's Avatar
cormorant71
On my '94 i removed the door panel.
Old Dec 9, 2014 | 07:27 PM
Retxpres's Avatar
Retxpres
Dave
How do you get that door handle trim off to get to the wire?
Just tried and stopped because I do not want to crack the trim.
Joe
Old Dec 9, 2014 | 07:52 PM
davewhtt's Avatar
davewhtt
Look into handle at eye level. 1 screw visible and another behind light lense. Search on here for door panel removal. The door handle cover comes off to remove panel. Do you have a FSN?
Old Dec 9, 2014 | 08:03 PM
Retxpres's Avatar
Retxpres
No fsm
To Passenger Door Light
