Black spiral wire wrap
Old Dec 23, 2014 | 12:23 PM
2Tarpon's Avatar
2Tarpon
Default Black spiral wire wrap
When I replaced the ignition wires on my '96 CE the black spiral wire wrap on the #6 and #8 spark plug wires was brittle and cracked. I bought some wire wrap that looked like it was the right stuff, from my local auto parts store. Subsequently, that's starting to melt and I need to find a better flame/heat resistant replacement. The only products that I find on line are in bulk quantities for well over $100...I only need two feet. Any one know where the correct 3/8" black flame resistant spiral wrap can be purchased in small quantities? Thanks, Paul
Old Dec 23, 2014 | 06:21 PM
CREWZIN's Avatar
CREWZIN
Do you mean the wrap that's made from plastic and split down the middle? If so, I have it on almost all my wires but there are a couple places that I can't because the heat is too much and they will crack and melt. I just don't put it on those particular wires. The 98% of the rest of the wire wraps are good to go for years. Sorry, don't have a close-up pic.
Old Dec 23, 2014 | 08:05 PM
SJW's Avatar
SJW
I don't have a specific product solution to offer, but I'd suggest you contact an applications engineer or technical sales rep at Tyco Electronics, and tell them you're in need of this material for a high-temperature application, and ask for a recommended product and distributor. They should be able to hook you up. If that doesn't get you a solution, ask the same sort of person at Digi-Key the same question.
Live well,
SJW
Old Dec 23, 2014 | 08:28 PM
joeld's Avatar
joeld
These folks should have what you need.
Joel
http://www.cabletiesandmore.com/Insu...Insulators.php
Old Dec 23, 2014 | 11:36 PM
RUU's Avatar
RUU
Sorry, can't help you with a source, but the first three photos in this post shows the black wrap around the red plug wires that the OP is looking for.
Old Dec 24, 2014 | 04:22 AM
Cliff Harris's Avatar
Cliff Harris
I think he's talking about the split loom pieces seen in this picture on the spark plug wires:
Mine got brittle and broke. I replaced them with something that looked the same that I got from Autozone. They melted. Apparently GM knows something Autozone doesn't.
Old Dec 24, 2014 | 05:15 AM
eutu1984's Avatar
eutu1984
2021 C4 of the Year - Modified Finalist
I was thinking of trying this product on my 90 to replace the cracked plastic ones.
http://www.summitracing.com/search/p...20Wire%20Wraps
Old Dec 24, 2014 | 07:55 AM
2Tarpon's Avatar
2Tarpon
Joel
Thanks Joel, I think this company does have what I'm looking for but it's $181.00 and they don't sell by the foot.
http://www.cabletiesandmore.com/amer...ses-p-7845.php
Old Dec 24, 2014 | 08:05 AM
2Tarpon's Avatar
2Tarpon
Carey, I purchased some high temperature, flame resistant, corrugated split wire loom like you're talking about. I'm having my car NCRS Flight Judged at the May 16th Plantation Inn Event. So, I need correct appearing stuff. I'll bring some for you Saturday evening if you would like to try it in the high heat areas...Paul
Old Dec 24, 2014 | 09:44 PM
Mose1's Avatar
Mose1
Default wire covering
Try wirecare.com. Did my whole engine bay and motor for about $60 bucks. Just my 2 cents. .
Old Dec 25, 2014 | 04:04 PM
CREWZIN's Avatar
CREWZIN
Paul, thanks. Appreciate the help with the high temp wrap but I'm up here in Virginia right now celebrating Xmas and New Years with the son and grandkids. Be back in the new year.
Old Jan 18, 2015 | 01:51 AM
Cliff Harris
The "normal" stuff just doesn't cut it in our environment:
I found this split loom, but they only have it in 1/4" and 1-1/4" sizes:
http://www.delcity.net/store/p_800823.h_66244.t_1
Here's some in 3/8" (what I need):
http://www.wiringproducts.com/3-8-inch-nylon-wire-loom
Old Jan 18, 2015 | 06:03 AM
2Tarpon's Avatar
2Tarpon
I finally found a 3/8" flame retardant spiral wrap for the number 6 and 8 spark plug wires that is working OK so far. It's only $1.60 per foot...not exactly the same as the factory installed, but close:
http://www.electriduct.com/Richco-Fl...ness-Wrap.html
Old Jan 19, 2015 | 01:18 AM
Cliff Harris
I put something like that on my auxiliary coolant fan switch wire. I got it from work, so I don't know anything about it's resistance to heat. I do know that it melted...
To Black spiral wire wrap
