Diagnostic Port Troubles
Old Dec 27, 2014 | 03:28 PM
mazdaverx7's Avatar
mazdaverx7
Default Diagnostic Port Troubles
Hooking up a scanner to read my check engine light on my 94 6 spd revealed an odd issue. The scanner is stating that it cannot connect. The ALDL is powering the scanner so I believe it has power. The cigar fuse is good. Here is a picture of the ALDL. Any advice would be helpful:
Old Dec 27, 2014 | 05:25 PM
WVZR-1's Avatar
WVZR-1
I believe that the DLC pin#16 is powered by the RH CTSY fuse #36. Do you have both "foot-well" lamps and courtesy lamps?
Check pin #16 should be orange for 12V.
What brand scanner? Does it work on a different car? Have you tried on another car? Can you?
Old Dec 27, 2014 | 06:29 PM
1993C4LT1's Avatar
1993C4LT1
Can you jump the connection?
Old Dec 27, 2014 | 06:56 PM
mazdaverx7's Avatar
mazdaverx7
I have both footwell lamps functioning properly
Old Dec 28, 2014 | 12:39 AM
Patsgarage's Avatar
Patsgarage
Is the scanner compatible with both OBD I and II ? Have you used that same scanner on your car before ? Even though that is an OBD II connector the 94 used OBD I. As suggested before, try the scanner on another car and see if it works.
Old Dec 28, 2014 | 10:23 AM
mazdaverx7's Avatar
mazdaverx7
The scanner works fine on other cars. I have tried more than one scanner on this car, to include taking the car to the dealer and having them try. Same results there as well.
Old Dec 28, 2014 | 11:03 AM
WVZR-1's Avatar
WVZR-1
If it's a C68 car does the information display properly when using it? Using the DIC can you access the CCM information?
http://tech.corvettecentral.com/2011...trouble-codes/
If the information isn't available from the DIC or the C68 panel then I'd think there are maybe CCM issues. Do the various DIC functions at "key-on" work?
From your snapshot the proper pins seem to be populated so I guess the next order of business would be confirming the proper "wire colors" are in the proper ports. I'm assuming that you for sure have a FSM to confirm that. 8A-50-1
Old Dec 28, 2014 | 11:30 AM
QCVette's Avatar
QCVette
Active Streak: 90 Days
Originally Posted by Patsgarage
Is the scanner compatible with both OBD I and II ? Have you used that same scanner on your car before ? Even though that is an OBD II connector the 94 used OBD I. ......
What brand and model is the scanner?
Most scanners are only OBD2 and will not work on the '94-'95 Corvettes even though they have an OBD2 connector. They are OBD1 cars.
Old Dec 29, 2014 | 01:56 AM
Cliff Harris's Avatar
Cliff Harris
I found this diagram on Google Images. I don't know how accurate it is:
To Diagnostic Port Troubles
