smog pump
Old Dec 31, 2014 | 12:07 AM
85vegasvette's Avatar
85vegasvette
Default smog pump
replaced the smog pump on my 85 with another, and runs fine question is the alternator bracket doesnt fit it is about a 1/2 inch off, will it be okay to run with out the bracket, or should i modify a bracket, i checked everything and it seems ok
Old Dec 31, 2014 | 01:46 AM
whalepirot's Avatar
whalepirot
Unsure which bracket you mean. The aft one reduces vibration and all that goes along with it. Frankly, it may be okay w/o, but I figure the GM bean counters wouldn't allow ANY parts that weren't necessary, according to engineering.
Ensure you're putting it back on the right way, too.
1/2" is a lot on that short sucker!
Old Dec 31, 2014 | 02:10 AM
Cliff Harris's Avatar
Cliff Harris
The engine vibration will cause the bracket to crack. That's why there are so many braces on the accessories.
Old Dec 31, 2014 | 12:21 PM
85vegasvette
yeah its the top wishbonebracket connceting the alternator and the pump, i took everything apart even down to the support bracket and re-traced my steps maybe got back alittle room but not much, i am gonna try and improvise something, does anybody know if the have the support bracket that goes from the intake to the pump?
Old Dec 31, 2014 | 12:38 PM
whalepirot's Avatar
whalepirot
Did you compare the old and replacement pumps? That would include the pulley diameter.
I wonder if you got the wrong new part.
Old Dec 31, 2014 | 01:32 PM
85vegasvette
yeah got one from pat, it was to wide and snapped the mounting bracket, pat ( who has a heart of gold, sent me another pump with the mouting bracket off and 85 went right in, im gonna play around again and retrace my senior moments to triple check i did it right, if not ill just got to lowes or home depot get some actual metal and form a bracket...
Old Dec 31, 2014 | 03:12 PM
Dt86's Avatar
Dt86
Maybe you got an 86-91 bracket? I believe your 85 is different.
Old Dec 31, 2014 | 03:25 PM
nutz4c4's Avatar
nutz4c4
That is correct..'85 was a one year only piece
Old Dec 31, 2014 | 03:52 PM
85vegasvette
Thanks guys gonna loosen the the belt take the smog pulley off then put the brace on see if it works
Old Dec 31, 2014 | 03:56 PM
Dt86's Avatar
Dt86
You're welcome. It always amazes me how many differences there are in the early C4's!
Old Dec 31, 2014 | 06:07 PM
85vegasvette
Well loosened the belt ,pulled the pulley off the pump , attached the alternator brace to te pump, a little pull with a screw driver down on the alternator ...and presto the aarp member is back I business , man it's a bitch getting old...thanks again rverybody
To smog pump
