I'm looking at a possible trade with my 1973 Roadrunner project for a 1993 Convertable. I have yet to see the car in person, but pics look great and the owner says it's pretty minty. She's a black LT1 auto, 80,000km.
What should I look for before committing to the trade? Are there any problem areas I should watch out for?
The seats are prone to wear and tear, at ~50k miles it shouldn't be an issue, but just something to look at. Weather stripping is a key point to look at, I'm replacing my 93's weather stripping soon. Test drive before you buy/trade (obviously). Other than that just make sure it runs well.
Good luck.
I have a 92 convertible, which I love. The soft top adds to the fun factor immensely. Be aware that there is precious little storage space in these cars unless it has a luggage rack on the back. I would pay attention to the condition of the top and especially the back window. The levers and buttons that are used to stow the top can be a little touchy at times, so be sure all of that works. The lever and cables to release the back bow from the deck lid are easily repaired and/or replaced with parts available on-line. The electrical switches to raise the deck lid are a little bit more of a problem if they are not working.
See if the owner has any maintenance records. If he has a FSM that's a good sign. Condition and age of tires, brakes and rotors, fluids, Check the top is good advice along with the weatherstripping. Insure the headlights open and close properly.
Obviously do a roadtest on it. Wouldn't hurt to pull a Carfax on it along with having a mechanic give it a once over. See if it's been repainted in the past and look & feel the body panels for previous repairs.
If possible, get it onto a lift or look it over on the underside. Many have been improperly lifted and can sustain body damage as a result.
I have an 86 convertible so the space issue is very valid if you plan on any trips with it.
Good luck and have fun!
Also, since it is a pre'95 C4 check to see if the optispark has been replaced, if not, stay away! Also, check the cooling system, if you need to do the opti or cooling, do both.
At this rate, no one on this forum will ever buy ANY car, since it will be too scary all the things that "might" go wrong.
Find a car you like, listen to it, run it, look at the tires, look at the guy who owns it.
Then buy it.
These are 20 to 30 year old cars - SOMEthing is going to be wrong with them. Heck, at the current prices, tires, brakes, seats, opti, wheels, starter .. pretty much everything is going to cost you $500 to $1000. Save a grand out of your buying budget to cover the stuff you didn't know about, and pay for it when it happens.
Or, go out and buy a $60,000 to $80,000 Corvette with a warranty.
And make $1000 per month payments. For eight years.
Then buy it.
Then buy it.
Add one more thing to the list if you look at a new one. Assume everything is sealed up unless you have umpteen dollars and your own personal mechanic, I doubt many if any people can work on the new ones themselves.
That's one thing I like about the C4's, you can do some of the work yourself without having $20K in diag gear and an electrical engineering degree.
Yup. I'm not much for doing my own work on the newer cars, but I have confidence I can handle pretty much anything "simple" on my '84. Even my '94 was getting more complicated, but still doable.
And .. if you have umpteen dollars, a few hundred bucks isn't even noticeable to put into your C4.
I wonder what it costs to put a brake booster or a starter into a C7...
