Jacking Procedure
Do I open the glass hatch? Do I leave the top bolted or unbolt it? Hood open or closed?
I have 2 floor jacks and would in most cases be jacking up two corners at once, like the entire side, or the whole front end, or rear end.
What if I was only jacking one corner?
Rick
What if I was only lacking one corner?
Rick
i have a crack on my targa as well on the 85 (just about to start a thread documenting how im going to fix it actually) but I have NEVER HAD AN ISSUE.
I dont know how anybody could have an issue really. Just get down on your belly and look under the car. I put my jack pan on an area of the frame where 3 or at least 2 of the "rails" meet. that way the weight is distributed over a larger area.
Also, grab either a puck, or wood, or something that isn't slippery, and put it on the pan of the jack. I found a semi truck mudflap in the ditch while taking a potty break on the side of the highway and i cut it in the shape of the pan and i use that on top of the pan.
I DO NOT jack where they say to jack between those lines. I find people crack the body panel trim piece when they do that.
LOOK for hoses/gas lines, get a flashlight.
It takes 10 minutes to get orientated under there on your belly using a flashflight and then you are good to go my friend.
I have jacked up my C4 from the driver side frame, right behind the front wheel, till 3 wheels are off the ground...[balanced between the floor jack and the pass side rear wheel] and I could still open and close the door with no problem. I don't recommend doing that, but I did it just to show a guy that you could.
http://forums.corvetteforum.com/c4-g...t-my-95-a.html
http://forums.corvetteforum.com/c4-g...placement.html
http://forums.corvetteforum.com/c4-g...cking-lt1.html
http://forums.corvetteforum.com/c4-g...nd-stands.html
http://forums.corvetteforum.com/c4-g...-question.html
http://forums.corvetteforum.com/c4-g...-jack-car.html
http://forums.corvetteforum.com/c4-g...p-the-car.html
http://forums.corvetteforum.com/c4-g...-lowering.html
http://forums.corvetteforum.com/c4-g...ing-sleep.html
http://forums.corvetteforum.com/c4-g...ack-point.html
http://forums.corvetteforum.com/c4-g...ck-stands.html
http://forums.corvetteforum.com/c4-g...oesnt-fit.html
http://forums.corvetteforum.com/c4-g...-87-vette.html
http://forums.corvetteforum.com/c4-g...acking-up.html
http://forums.corvetteforum.com/c4-g...the-c-4-a.html
http://forums.corvetteforum.com/c4-g...e-jacking.html
http://forums.corvetteforum.com/c4-g...e-92-vert.html
http://forums.corvetteforum.com/c4-g...ng-points.html
http://forums.corvetteforum.com/c4-g...ng-car-up.html
http://forums.corvetteforum.com/c4-g...g-up-a-c4.html
http://forums.corvetteforum.com/c4-g...the-vette.html
http://forums.corvetteforum.com/c4-g...g-an-88-a.html
http://forums.corvetteforum.com/c4-g...-up-my-c4.html
http://forums.corvetteforum.com/c4-g...ts-1985-a.html
http://forums.corvetteforum.com/c4-g...n-the-air.html
The post was aimed towards PLRX, not the OP. Pete is a great guy that usually always has something insightful to add. I just know he was being a wise guy and going out of his way to post links to a ton of threads about "jacking procedures" instead of just giving a simple reply that takes all of 15 seconds.
I do think I will go ahead and take that vacation though.
I come here for discussion and to be social. I find answers all the time when Google loops me back to this forum. However, having to wade through threads of 200 posts that mostly don't have anything constructive regarding the OP question is tiring.
Googling for 45 minutes is nothing like posting a question and getting answers that exactly relate to YOUR question, not finding 500 posts that are close, but not really what you're looking for.
Finding an answer sometimes winds up being just a plus. Community discussion is what a forum is all about. If we all just got our answer and moved on, there'd be no more answers to Google.
Spot on!
This is how I lift my car with floor jack and stands:
Place a short 2x4 on the cradle of my floor jack.
Place 2x4 under CENTER of side rail, I never noticed if it was below the mirror.
Lift one side of the car to about 1.5 feet off the ground (tires about 4-5 inches off the ground I guess).
Position jack stands as high as possible at proper locations or obvious frame points, slowly lower car onto stands while watching stand contact points and adjusting accordingly.
Same procedure lifting other side.
During the process I make sure all 4 stands are at the same height/notch.
Push/bump car firmly to be sure it's secure on the stands.
If I'm taking the wheels off, I place them under the car to protect me if the stands fail or something else happens. If I'm not taking the tires off, I keep the jack stand cradle 1/2" below the side rail of whatever side I'm crawling under... just 2nd level security beyond the jack stands supporting the weight of the car.
If a car was structurally really that weak, it doesn't seem it would make a very good sports car. And this is a very good sports car.
