SLP cold air induction
Old May 2, 2018 | 01:23 PM
  #41
aklim's Avatar
aklim
Originally Posted by pologreen1
IMO A dyno can be off each run as much as these add or don't add.
I think Suzie59 should offer this piece up to test on other c4's just so others can see what is happening.
True but if you make say 5 pulls, you can average any power gain. Thing is, I honestly don't know how sensitive the Butt Dyno is. Can you feel a 10 HP gain? How about 8 HP? 5 HP? Say you can feel a 5HP difference, you state you can feel the difference with this doohicky. Kinda tells me this doohicky makes at least 5 or more HP.
Old May 2, 2018 | 03:15 PM
  #42
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Depends on the car....and the butt-o-meter, too. I've posted many-a-time about how my LT1 feels just about exactly as fast as my C6 LS2 felt. There was an 87 RWHP diff between those two cars. If someone is talking about "feeling" 5 hp...they're feeling the psychology of 5hp, IMO.
Old May 2, 2018 | 04:20 PM
  #43
aklim's Avatar
aklim
I'd actually like to see someone's ability to tell the difference between one car with and the SAME car without and see if they can consistently tell the difference. My money is on "NO".
Old May 2, 2018 | 06:02 PM
  #44
pologreen1's Avatar
pologreen1
I think it is possible at a certain of the build point of a car.
A really lightweight car will obviously react better to it. The other thing in mind at least thinking aloud is maybe depends on what range of the powerband the new HP falls in.
Mine never felt gains that were not substantial mods. (I have mentioned cold weather with the ram air intake I had. My guess is most would say it improved power.)
In my case I blame the suspension at the time, the stock tune, and the fact that you just simply won't notice a couple hp.
Not bragging, but on our cruise there was a point I was accidentally boiling the tires trying to get across the intersection as a car was coming at me and me rolling in to it drive like normal from a stop sign. That feels a a lot different than 250hp than going to 260 and takes longer to get used to it.
I think butt dyno would need an L98 to get full exhaust or intake change to really notice anything other than the sound and placebo effect. Maybe the doohickie butt dyno jsut says "hey, I did not totally waste $300.00, because I can feel it maybe..."
In the end to me me who cares about 20hp when you only make 250? Maybe in a race at a track for brackets.
20hp matters to me now, because I am limited by my trans only being built for 750-800. If I was racing it I'd care for more, but then I'd change the trans and push the full 1200hp it's built too.
Old May 2, 2018 | 06:09 PM
  #45
pologreen1's Avatar
pologreen1
for sure, and then you get in to HP for HP your C4 will FEEL way more powerful.
I know my car "feels" way scarier than a new car with the same HP. Put a racing seat in it and it will be as raw as it gets, with good suspension and stuff.
I mean a ragged out 5.0 mustang with 300hp and terrible suspension will make a guy crap his pants for sure... But a c5 Z will murder it.
Old May 2, 2018 | 11:12 PM
  #46
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
That is incredibly true.
Old May 3, 2018 | 08:25 AM
  #47
aklim's Avatar
aklim
I'm not sure we are sensitive enough to feel slight differences when it comes to the same car with and without the modification. 30 HP difference is more likely to be felt than 3 HP difference. Even the conical filter on the TB didn't give me 30 over the slutted stock filter grille with the K&N filter instead of paper on the dyno.
Just a little time longer
