Camber question
Old Aug 8, 2002 | 02:24 AM
RadPolo96's Avatar
RadPolo96
Default Camber question
Last year i dropped the back end. After that my camber on my back wheels has been off and the wheels are Toed in. How can I fix this? Do I have to get a new camber kit or can I get a front dropping kit that will even the car out and fix the camber prob? Any suggestions would help :D
Old Aug 8, 2002 | 11:36 AM
vettmech's Avatar
vettmech
Default Re: Camber question (RadPolo96)
It needs to be aligned. The camber is easily adustable and infact the whole car is easily aligned
Old Aug 8, 2002 | 11:38 AM
vader86's Avatar
vader86
Default Re: Camber question (vettmech)
you need a full alignment
Old Aug 8, 2002 | 12:07 PM
RadPolo96's Avatar
RadPolo96
Default Re: Camber question (vader86)
The thing is...they said that my camber is maxed out and they aligned it the best they could. My only other option is to get a camber kit to fix the problem.
Old Aug 8, 2002 | 11:27 PM
BrianCunningham's Avatar
BrianCunningham
From: Boston, Dallas, Detroit, SoCal, back to Boston MA
How much did you drop it?
What are the current specs?
What would you like?
What do you do with it? Autocross? Drag? Road race? Daily Driver?
The toe is adjusted by links, just like the front minus the steering rack.
If you can't get enough adjustment using the factory adjusters ( which I find strange :confused: ) you can get aftermarket strut rods which replace them.
Old Aug 8, 2002 | 11:49 PM
RadPolo96's Avatar
RadPolo96
Default Re: Camber question (BrianCunningham)
I think that its lowered about an inch to an inch and a 1/2. Not a whole lot...but an alignment guy with the hunter system couldnt do it and the same with a corvette specialist in San Antonio. The told me I would have to get a camber kit that is fully adjustable. I plane on just using it for daily driver and the occasional street race :D
Old Aug 9, 2002 | 12:19 AM
BrianCunningham
That's not that much.
you have a digital camera?
If so take a picture of the adjusters, located under the diff, from the back
there's indictators.
You could have worn out bushings, but I'd like to see if they are actually maxed out.
Toe, no excuse there, unless they are at the limit.
Our cars are so stiff you have to:
1) set the camber
2) drive it around the block
3) then set the toe
both front and back, otherwise it won't settle.
Old Aug 9, 2002 | 12:38 AM
RadPolo96's Avatar
RadPolo96
Yeah...i think I have worn some bushings. I dont have a camera on me...but both guys said that it was maxed.
Old Aug 9, 2002 | 01:22 AM
jefft84's Avatar
jefft84
I do alignments for a living the C4 should be fully adjustable with factory adjusters with 1 1/2 lower suspension. I agree with the others if its really at max there is another problem. But in any case I have never maxed out the toe adjustment on any C4.
Old Aug 9, 2002 | 01:25 AM
RadPolo96's Avatar
RadPolo96
Default Re: Camber question (jefft84)
So what are possible thing that could cause it?
Old Aug 9, 2002 | 09:02 PM
VetteNoob's Avatar
VetteNoob
Here are some pics of his camber adjustments Right and Left respectively.
RIGHT:
LEFT:
Old Aug 9, 2002 | 11:31 PM
Ericthewolf's Avatar
Ericthewolf
Default Re: Camber question (VetteNoob)
Both sides are still adjustable by the pics posted. Go somewhere else to get it fixed. Reccomend somwhere they have a 3d aligner..
Old Aug 10, 2002 | 02:48 AM
RadPolo96's Avatar
RadPolo96
Thanx for posting the pics man.
Old Aug 10, 2002 | 02:54 AM
VetteNoob's Avatar
VetteNoob
Np. Next time drop the hammer. Quit giving me a false sense of HP! :lol:
Old Aug 10, 2002 | 08:22 PM
RadPolo96's Avatar
RadPolo96
Np, dude...I quess she didnt feel like down shiftin :rolleyes:
To Camber question
