C4 PKE question
Old Feb 10, 2015 | 10:08 AM
karkrazy1971's Avatar
karkrazy1971
Default C4 PKE question
I have a 96 LT4 that I just received the factory key fob which didn't come with the car. I followed the instructions to a T and the PKE light never came on. I took the car to Chevy and they told me someone installed an aftermarket driver information center?
Can anyone confirm or deny whether this is a stock item or not? Chevy is telling me they have to tear the dash apart to find the part number before the key fob can be paired. The information panel that I'm talking about is installed directly above where the air condition controls are. I'll try to post a picture later after work.
Old Feb 10, 2015 | 10:46 AM
markKlein's Avatar
markKlein
An aftermarket DIC? Huh. What does it look like? Does it match what the owners manual shows? Does the PKE light ever come on?
If the PKE receiver is working you don't need to take anything apart to program a fob. I'm not sure what they are talking about. Unfortunately a lot of receivers have stopped working over the years.
You might check the fuses, 26 40 and 42.
It would help if you listed each step you did in programming (believe it or not, this one time a guy thought he did just what he was supposed to do, but was mistaken) and what happened.
Old Feb 10, 2015 | 10:57 AM
karkrazy1971
Unfortunately I don't have the owner's manual, but will be doing a search for one online. The information panel looks like a touch screen radio. The instructions for the key fob were to move it 10 feet away. Next it stated to press the trip/odo twice then the fuel/info within 5 seconds. This is supposed to activate the PKE, but nothing happens for me. I'll check those fuses when I get home. It'd be nice if it were something that simple. Otherwise, I'll be going with an aftermarket system.
Old Feb 10, 2015 | 11:01 AM
karkrazy1971
Here is a picture of the panel I'm referring to. I think the dealer was wrong. Looks stock to me.
Old Feb 10, 2015 | 11:21 AM
markKlein's Avatar
markKlein
A couple things you didn't mention. The key should be in, ignition in ON position, doors closed. Also you are supposed to press and hold FUEL INFO until PKE light start to flash, did you just push it and let go?
One more question, do the trip/odo and fuel/info buttons work normally?
Try this for an owners manual
http://justgivemethedamnmanual.com/c...wners-manuals/
Old Feb 10, 2015 | 12:04 PM
karkrazy1971
Yes, you hit it right on the nose. I tried with the doors open and closed. No matter how long I held the fuel/info button there was no pke light. The buttons work otherwise and it cycles through all the choices as I hold down the button. The key fob came with the instructions which are not complicated. It just doesn't work for me. Either it's a fuse like you mentioned or something in the system.
Old Feb 10, 2015 | 12:07 PM
markKlein's Avatar
markKlein
Looks stock to me. If the fuses are OK you probably have a bad receiver, lots of threads here on replacing them, I've never done it. Good luck
I'm not sure I would go back to that Chevy dealer.
Old Feb 10, 2015 | 12:15 PM
karkrazy1971
Thanks for replying. Hopefully it's something simple. Otherwise, it's time to upgrade to new technology.
Old Feb 10, 2015 | 12:23 PM
kg4fku's Avatar
kg4fku
Did you check to see if the light bulb was good in the DIC?
Old Feb 10, 2015 | 12:40 PM
karkrazy1971
Good question. Last resort, I may tear into the dash and check. I was looking for the lazy way to get the key fob working
Old Feb 10, 2015 | 12:48 PM
kg4fku's Avatar
kg4fku
Well this is what I would do then.
Do everything as the procedure states. When you are supposed to get the PKE light just assume it is lit and proceed to the next step.
If it works then you can assume something is wrong with the bulb or light circuit.
If it doesn't then you can assume it is something a little more involving.
Worth a shot.
Old Feb 10, 2015 | 02:50 PM
karkrazy1971
Worth a shot.
Sounds good. I'll give it a shot when I get home
Old Feb 10, 2015 | 07:32 PM
sledge_78's Avatar
sledge_78
I don't think your dealer is knowledgeable with the C4 PKE system. If you say you have followed the procedures to add the remote and it does't accept it this may be the cause: The PKE system will accept up to three remote FOB's. Since you are not the original owner there may have been three already programmed into the system. When you try to add another it rejects it. Apparently as I have learned the system does not "over ride" a programmed FOB. As I learned, You will have to have a knowledgeble dealership erase the PKE systems memory and re-program your new FOB into the system. Realistically, the PKE system in the C4's are finicky.
Sledge_78
Old Feb 11, 2015 | 08:48 AM
karkrazy1971
Sledge_78
I think you are correct. The PKE system doesn't seem to be on nor will it go into program mode. I've searched and be unable to find the procedure for clearing the previous key fobs. Going to call some of the dealers and see if I can find someone that knows what they are doing.
Old Feb 11, 2015 | 10:00 AM
markKlein's Avatar
markKlein
Sledge_78
This is entirely incorrect. A properly working system will accept up to three fobs at one time. When you program a fob it drops all previous fobs and replaces them with those programmed in your latest session.
karkrazy - unless your bulb is burned out, 95% chance your receiver has failed.
Old Feb 11, 2015 | 11:46 AM
RollaMo-LT4's Avatar
RollaMo-LT4
St. Jude 15 Year Donor
2021 C4 of the Year - Unmodified Finalist
St. Jude Donor '10 thru '25
This is entirely incorrect. A properly working system will accept up to three fobs at one time. When you program a fob it drops all previous fobs and replaces then with those programmed in your latest session.
Mark is correct.
Old Feb 11, 2015 | 03:54 PM
sledge_78's Avatar
sledge_78
Mark,
I will always admit when I'm wrong. when I had problems with my PKE system and searched through RCU for resolution I came accross a somewhat knowledgeable member at the time who mentioned the PKE not accepting new FOB when three had already been accepeted. Although that was not my problem, I remembered the statement made and passed it along here as a possible solution. In fact, I did think it was a poor methodology for GM to implement but thought anything was possible. I'll remember next time to pass on facts rather than hear say.
Sledge_78
To C4 PKE question
Old Feb 11, 2015 | 04:02 PM
sledge_78's Avatar
sledge_78
Karkrazy,
When I had problems with my PKE system I thought it was the Receiver so, I purchased another from a parts recycler. If you determine that yours needs to be replaced I have one which I would sell to you for exactly what I paid ($95.00 + shipping). Here is the info on the unit label:
Lectron Products inc.
Rochester, Michigan
Model GM202R
Doc: 218 K768
If interested let me know.
Sledge_78
Old Feb 11, 2015 | 05:34 PM
markKlein's Avatar
markKlein
Mark,
Sledge_78
Didn't mean to offend. I've seen that on the forum too, not sure how it got started. Kind of like when someone decides they can't do the programming procedure because the system is turned "off".
Old Feb 12, 2015 | 08:40 AM
karkrazy1971
Karkrazy,
Rochester, Michigan
Model GM202R
Doc: 218 K768
Sledge_78
I took the car to another dealer that actually knew what they were doing. They couldn't get the car to go into programming mode. I was told it was most likely the PKE module, but they can't state for sure. I'm trying to decide if I'm going to put any more time and money into the OEM system or get something from Best Buy. I'll let you know either way.
