1988 A/C question
Old Feb 14, 2015 | 07:42 PM
Rockcrushervette's Avatar
Rockcrushervette
Default 1988 A/C question
Few weeks ago blower started vibrating and stopped! Pulled it out cleaned it oiled bearings and works better then ever! This week the a/c fuse blows! Put in fuse air works blows fuse when turn on a/c! Disconnect fan doesn't blow fuse but clutch didn't kick in ( new clutch 3 months) I looked down and I am to believe the low pressure? Switch next to dip stick wires were hot started smoking? I turned off a/c ! Is that a low pressure switch? Can I bypass it just to make sure clutch will kick on before I go further and buy another? The system was converted to 134a before I bought car
Thanks for ideas
Cliff
Old Feb 14, 2015 | 11:14 PM
jv9999's Avatar
jv9999
You need to measure the amp draw of the clutch. Sounds like it's bad to me. Chinese aftermarket?
