Climate control
Old Feb 22, 2015 | 11:45 PM
Nicksvette's Avatar
Nicksvette
Default Climate control
I'm a bit new here to posting so sorry if this is a dupe or a silly question as i couldn't find this answered anywhere else. i own a 88 vett and its a blast but one minor issue as summer is approaching and getting warmer, not a problem for a lot of you buried in snow atm , my concern for my cold air is becoming greater. Now, my problem is that after about 3-5 minutes of driving, the car will just start blowing full heat and nothing i do will stop it. I've tested it when it's 68 up to 82 and no matter what setting i have the c68 climate control set to, it will blow heat. However, when the car first starts and is NOT warm, the car will blow out nice cold air. side note, even when the car is blasting hot air through the vents, I've opened the hood and could see the compressor going and the high and cold lines to the compressor are VERY cold and most of the time have condensation all around it. any expert or someone who could help me please chime in as i wish to have nice cold air flowing through the vents. No check engine light although don't know why there would be one. As far as I'm aware there are no obvious vacuum leaks
Old Feb 23, 2015 | 09:43 PM
Nicksvette's Avatar
Nicksvette
Bump
Old Feb 23, 2015 | 09:57 PM
zr1fred's Avatar
zr1fred
Veteran: Marine Corps
It sounds like you have a controller issue (the box on the firewall to the right of the accelerator pedal with all the different colored vacuum lines coming out of it). Or possibly the heater door. Both are under the dash.
Old Feb 23, 2015 | 11:31 PM
Nicksvette's Avatar
Nicksvette
holy cow what a rats nest. so let me start this off at this, a few months back when i first noticed the controls were all bugged up was right after my dad had brother the vett in to a mechanic to get the clutch and brake master cylinder fixed as it had a leak. that is when my problem started and they apparently had to replace the master cylinder and who knows what else they touched. when i got it back, the first thing i noticed was the vacuum line that runs from the little vacuum ball to the T splice had been disconnected and tucked away. so i replaced it and the idle got better but my climate control didn't. here we are now with this absolute rats nest of cables that some have been corroded, connected with electrical tape or worse duct tape and some completely unprotected and loose, YIKES
don't know if this is the problem but i've circled where it looks like a missing connector would go
good lord this looks like a mess. Dear last owner, what did you do under the dash
Old Feb 24, 2015 | 03:53 AM
Cliff Harris's Avatar
Cliff Harris
You might have a bad or disconnected vacuum check valve. It supplies vacuum to the HVAC system in the cabin. It also supplies vacuum to the cruise control, so check to see if that works. The vacuum check valve (about $4 at any auto parts store) is located next to the distributor on the driver's side:
Old Feb 24, 2015 | 09:01 AM
Nicksvette's Avatar
Nicksvette
Found it but would there be anyway to test it instead of replacing it?
As far as I can see, it's connected and tight
Old Feb 24, 2015 | 11:27 AM
86C4Z51's Avatar
86C4Z51
Apply vacuum on one side then the other. Should only allow air to pass one way. Get a mighty vac or use your lips.
Old Feb 24, 2015 | 12:26 PM
Nicksvette's Avatar
Nicksvette
there might be a small leak but it wasn't a big leak. I'l replace it though anyways because its an old part with cracks and very brittle plastic.
Old Feb 24, 2015 | 12:31 PM
Nicksvette's Avatar
Nicksvette
i don't know if yours is just disconnected but mine connects to where the single side goes directly to the headers and the other two sides go, one to what i guess to be the interior (very very tiny little, almost coffee straw like tube) and the other over to the vaccuum ball/cruise control.
Old Feb 25, 2015 | 01:49 AM
Cliff Harris
One side goes into the cabin and supples vacuum to make all the HVAC controls work. The other side goes to the cruise control and also the round vacuum tank. The vacuum source is a port on the passenger side of the plenum.
Old Mar 19, 2015 | 12:04 PM
Nicksvette's Avatar
Nicksvette
Default Fixed
Well, not wanting to leave a story unfinished, I finally fixed it. What happened was the actuator for the blower blend door was slightly broken and caused it to malfunction whilst it was going. Highly unlikely that it will happen again but it's fixed now :3
Old Mar 19, 2015 | 12:27 PM
86C4Z51's Avatar
86C4Z51
Thanks for the update, Nick.
To Climate control
