1992 Ignition Switch question
But here's my question.. In order to do this repair the ignition switch had to be moved part way out of the other side of the column so that the upper column housing could be separated from the lower.
I put the switch in the locked position with the key then removed the key and pulled the ignition switch out partially, then when I was done I pushed the ignition switch back in place and tightened it's locking screw in place. I have everything back on the column EXCEPT the steering locking plate, the airbag coil, steering wheel and airbag.....
Before I put them on I wanted to try the directionals with the battery reconnected and the ignition switch on. BUT when I put the key in the ignition switch it will not turn !!! Is that to be expected with the items I mentioned above still off the column ? I really don't want to put those back on until I know for sure whether or not I should be able to turn the ignition switch at this point ...... That snap ring that holds the locking plate on is a real pain to get on and off !!! Let me know if you
have any idea if the locking plate and steering wheel have to back on before you can turn the key..... Or did not leaving the key in the switch after I locked it have anything to do with this ..... Thanks !!!
OK... put the turn signal switch back in and the small bracket that mounts to it and supports the directional lever/ multifunction switch. The mechanisms work nice now... can click on left and right directionals, brights on and off and turn the hazards on and off ...... Battery has been disconnected all the time I have been working on this, But when I reconnect the battery and turn the ignition key on,, the dash lights up and the chime chimes, but the directional lights do not come on or neither do the hazards or can I turn the wipers on when I activate each switch ...... mechanically it all works, but electrically it does not,,, and the connectors are all plugged in, I checked..... I do have the airbag fuse out since I have not put the locking plate / airbag coil / steering wheel or airbag back on ... Want to make sure that the switches all work before I do that..... Does the airbag fuse have to be in for the column to function electrically ? I don't have a wiring diagram.... Can I put the fuse back in and test the directionals, etc without the airbag back on ?? Taking my time on this because I know what I pain it is to get that locking plate snap ring on and off... don't want to do that until I know everything below it is fine ....... Thanks...
I wouldn't think the SIR fuse controls what you say doesn't work BUT some GM won't crank/run with blown or missing SIR fuse. First inclination would be problem with connectors on the column but you say you've checked. You can put the SIR fuse in.
Do the stop/brake lights work? Do back-up lamps work?
Check the individual fuses for turn, wiper etc.
I now have the airbag clockspring on too.... since I didn't take the column out or release the locking mechanism on it,, I just placed it back on the column the way it was when I took it off ... All that's left is the steering wheel and the airbag......
Pointers I would pass along are:
1. To get that wire ring off that holds the locking plate on I used 2 small flat blade screwdrivers.... prying it out of the groove by getting under the it in the groove away from the open end and then using the second screwdriver to pry the two ends out..... then just wiggle it up the shaft.... patience.....
2. To get the pin out that mounts the multifunction switch to the upper column housing, you have to separate the upper housing from the lower by about an inch or so.... then you can push the pin out from the top with a small diameter punch or any pin-like thing you can find that will fit in there. Then remove the multifunction switch from the column. Before you pull the cable up and out of the column make sure you tie a string or wire to it that you can later use to pull the new switch cable down the column.
3. When putting the upper and lower column sections back together make sure you have the headlights brights rod lined up on the multifunction switch end (top) and the dimmer switch end (bottom).. Takes alittle positioning of the rod but it is very doable...
4. Another problem I had to deal with was the ignition key cylinder to ignition switch [which is mounted down by the dimmer switch] mechanical rack assembly alignment went out when I separated the upper and lower column. The Field Service Manual has a good picture of how this needs to be aligned, and one of the replies above in this post has a link to it. What I had to do was just realign it by gently prying the rack into position... Didn't require too much force just some easy nudging ....
5. Make sure all the wires go down the bottom side of the column, just like they did before you started, especially if you have an airbag... While you are positioning the wires / cables make sure that there is not too much slack in there.. you don't want any of them getting kinked or rubbed as the steering wheel is turned. Make sure to put that plastic protector back in around the wires at the bottom of the column when you are all done...
6. If you have an airbag, be sure to avoid hitting the release button on the back of the clockspring mechanism... that way you can just put it back on just as it was when you are done without having to reset the clockspring. However, if you need to do that reset, it's not that bad and is described in the FSM.
7. Most important ... as you are disassembling the column.... Use your smartphone or camera and take pictures at each step.... that way when you get to putting all the stuff back together you can see what it looked like before you got in there and messed with it ... That helped me ALOT ! I have some photo's that I can post if anyone thinks they might help..... I just have to remember how to post them on this site...
8. I bought the multifunction switch off of Ebay for $80. It appeared to be of good quality to me.. The company /seller claims he gets them from the GM supplier,, for what it's worth.. I believe he is based in Atlanta... SpecialtyPartsDirect http://www.ebay.com/itm/230817504014
This part can cost much more from other sources...... not sure if you would be getting anything better for the extra $$$...
Keep them American musclecars runnin' .........
