Other than ebay, does anyone have any suggestions on where the best places would be for me to look to find a Tech 1? I just picked up a 1994 Jimmy 4x4, and since I now have 2 OBD1 rides, I figured it's time to spring for the most important tool I need to give my stable complete support. I do not want some cheapo knock-off aftermarket glorified code reader...I want the real deal that will allow me to give the '87 and the Jimmy complete factory level support.
Other than Tech 1 scan tool itself, what specific modules, cables, etc... should I look for to be included to give me complete support through 1994?
As a side note, I plugged a WTB ad in the C4 Parts section, but wanted to expand my search as wide as possible---I realize not everybody reads the C4 Parts section, so expanding the search starts here.
It depends on how much you want to do with the scanner. I have a Craftsman that reads both OBD I & II using different adapter cables. It works fine for basic troubleshooting, but for more involved jobs I do go back to the Tech II. You can also check the Snap On forums, they may have a for sale section.
Heck, I can read codes on these two OBD I'ers by grounding pins B to A...and breaking out the FSM. But what I'm wanting is a scanner that I can read sensor values on, perform diagnostic test outlined in the FSM, etc...in other words, I want to be able to do everything the dealer could do, and no less.
I've never researched the Snap-On scanners, but that's about to change now. I need to find out what their capabilities are, and if there are models that can do what I outlined above....starting with the MT2500 mentioned by Bandit.
There are 3 cartridges I'd try to get so you have the most use of that scanner over a wide range of obd1 GM cars-
1)3000003 mass storage cartridge
2)3000003 mass storage cartridge
3)3000003 mass storage cartridge
(it is an all in one big memory cartridge that does everything to all the cars. i think it is only limited by the year it was programmed and newer models after that year would obviously not be included.
Right-o, which is the same method I use as outlines above, BUT...that's all you can do there. Again, I want the ability to have bi-directional diagnostic capabilities, the ability to look at live ecm values of sensors, etc... and that can only be done with the proper scan tool.
A few videos available on youtube... the MT2500 does have live bi-directional capability.
There is a scrolling wheel (like on a mouse) that allows you to scroll thru the live data.
Note the first video - diagnosing a bad O2 sensor on an LT1.
I'm looking into those MT2500's now, and I like what I see.
One thing I know is that not every problem posts a code...for example: Rough idle when cold, idle smooths out when warm, no codes present. To fix a problem like this without diagnostic capabilities would involve implementation of the backyard-shadetree-mechanic methods of guessing, tail chasing, and parts shotgunning...to get directly to the source of a problem like that requires real-time scanning of components (ie coolant temp, etc...) to know what's going on when, and the ability to test questionable components.
One question I have is if the Tech2 scanners have any backward compatibility using cord adapters to emulate the Tech1 functions? Also the bosch-vetronix MTS 3100 scanner is sort of the successor to the tech1 line and might also be functional with obd1 GM stuff since it is the same maker as the Tech1/1A scan tools.
Yes, I have used my Solus (Tech II) on my 95 on several occasions. It reads all real time data, and can do more depending on make/model/year. You do need an adapter cable as well as a power cord, as there in no power on OBD I connections.
You can put batteries in the unit, but I am leery of leaving them in for long periods of time. Most of the time I use it for OBD II, which has 12v at the connector. On the rare occasions that I need it for one of my OBD I cars I just dig out the power adapter cable.
Another old thread brought back from the dead. Well, since this thread has been resurrected, I will add that I ended up finding a Tech1 with a master cartridge, F/Y adapter, cables, books, and case for $125.00 back in 2015.
